Question about Singer 7462 Mechanical Sewing Machine
Light goes out when I start to sew
I am using my mother's 50 year old kenmore sewing machine and when I start to sew the light on the machine goes out
  • 706 Answers
This may or may not help.. first UNPLUG it..then unscrew the light bulb and look at the base of the bulb socket.. you should see a tang there ( small tab) that makes contact with the bulb.. sometimes that gets compressed to a point that it won't make electrical contact with the bulb or intermittent contact and the bulb flickers.. You may also have a loose wire on the socket terminals too.. Depending on your electrical skil level, you may or may not want to look into repairing that yourself.. Hope this helps..
Posted on Oct 11, 2008
Where can I buy a manual for my Kenmore sewing machine?
"need make and model of the sewing machine in order to help you."
Nov 07, 2015 | Kenmore Sewing Machines
How long is sewing thread good for
As long as sewing thread is kept in a dry place - often a biscuit tin or one that has held confectionary is used - then it should remain in good condition for a very long time. I have cotton which is probably 30 years old, and some inherited reels which could be up to 50 years old and which are still in perfect condition.
May 02, 2014 | Kenmore 11206 / 11306 / 11506 / 11606
Hello I have an old sewing machine and would like to know what its worth it was my moms about 50 years ago its a kenmore 117-552 Serial n is 376239/ tHANKS
Hi. Unfortunately, sewing machines were manufactured by the millions and those from 50 years ago are still going strong and readily available. The value of any sewing machine is determined by how much someone is willing to pay for it. There are some older machines that collectors will pay good money for, if the machine is in excellent shape and has all the attachments. To get an idea of what people are willing to pay for your machine, check the listings in Ebay. There is a vintage kenmore group on yahoo groups that you can check also.
Hope this helps,
Robbie
Aug 11, 2010 | Sewing Machines
4t year old kenmore sewing machine model 52 has always worked fine. I use it all the time. Zigzag seems stuck and wont move back and forth after oiling. Don't know if oiling had anything to do with it. Has...
maybe a service call is in order. I have a 30 year old huskavarna can't spell it, but the repair people said they don't make the machines out of metal anymore so if you have one you liked it is worth the 200.00 of it needs a new part, and they clean them really well as well, good luck hope it works K
Sep 21, 2017 | Kenmore Sewing Machines
Thread goes off screw when i start sewing
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Kenmore Owners Manual
Jul 03, 2009 | Kenmore 15358
E1 error on Kenmore sewing machine model 385.19233
Jul 20, 2008 | Kenmore Sewing Machines
Availability of needles
Practically every machine made in the last 50 years uses a 15x1 needle also known as 130/705 universal fit.
sewman7
Jul 11, 2008 | Kenmore Sewing Machines
Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Jul 05, 2008 | Elna 2007 Mechanical Sewing Machine
Kenmore foot peddle going too fast to sew
The problem is either in the foot control or there is a short in your wiring. You can replace the foot control and hope that's where the problem is or Take it to a technician to be sure..The foot control will probably cost around $30-$50.
sewman7
Jun 30, 2008 | Kenmore 15208 Mechanical Sewing Machine
Inserting needle on old singer machine
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Dec 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer 7462 Mechanical Sewing Machine Logo
120 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
