Question about Car Audio & Video
Connection guide for clarion 2170E
Wish to wire up old radio need details of what the connections on the back do
  • 3 Answers
my name is Johnathan and i will be helping you to day, your question was wiring up an old radio and you need to know what the connections on the back do.so we have mostly 2 different connections 1is the antenna and the other is your wire's for power and sound now on the back of the radio will be a collared wir's
red- for you ACC which will get attached to a switched power 12 volt source
yellow- will get connected to 12 volt's constant like you battery caution
(risck of shock)
black- will get hooked up to the body of the car either to the Chase or their will be a solid black wire.
After you have all the power hooked up you should have 6 wire's left 3 solid and 3 with a black strip the solid's will be positive(+) and the wire's withe the black strip will be negitiv(-) and after you have all your wire's hooked up you should be able to enjoy so good music so enjoy. and i hope i was helpful.
Posted on Oct 11, 2008
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
I need a wiring diagram to hook up a new radio.
First you will need to get a wire harness for your specific make, model & year of car. This will interface the car wiring plug to your new clarion headunit.
Next you will connect the wires from your purchased wire harness to the wires of your Clarion Headunit. Using **** connectors with a wire crimper is the best way to do so.
Here is a wire color coding guide for the wires on your Clarion headunit:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Mar 17, 2011 | Clarion Car Audio & Video
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
My Clarion AM/FM,CDMP3,marine radio will play when...
    I had the same issue with a blown speaker that was shorting it
    self out. I found this on "TeamClarion.com" site.
    Step 1: Disconnect all the speakers from the head unit and try again. If the same message comes up, send the unit in for service.
    Step 2: If the message goes away, you have a wiring problem. Check each speaker lead for a short circuit, damaged speaker or a ground to chassis.
    Basically means one set (or more) of the speaker leads are touching each other (shorting out). This can be somewhere inline to your speakers or your speakers them selves. The advise above isn't to clear. In the first step they want to rule out the speakers attached but "disonnecting all the speakers" is vague. You should disconnect at the rear of the radio. This might be difficult because the multi plug in the back has the speakers and power wires together (at least most clarions). Also if it was a good install then the outgoing speaker wires were soldered to the long run speaker wires going to the speakers.
    To truly test for radio fault verses the wiring or speakers, you have to sever the connection at the back of the radio. If this is not something you wish to do then there is one suggestion. Order a new multi plug for the back of the radio. This way you can pull the old plug and test it with a new plug with no speakers attached (just have to run 12v positive and negative).
    If the radio is OK then start by checking all the wires to your speakers (if possible). If nothing seems bare and shorting (remember it's usually in tight places or were the wires are hanging loose that vibration will cause cutting to the wire) then disconnect all your speakers (at the rear of the speakers). Turn the radio back on and see if it does the error message again. If not reattach the speakers one by one checking for the error message.
    You can check these in any order. If you don’t want to order a new plug then you and can’t get to much of the wiring to physically check then starting at the speakers is OK.
May 20, 2010 | Clarion CX609 Car CD/ MP3 Player
Clarion DXZ785USB - Connecting Fused Lines
You will definitely need to connect the Yellow Wire Memory Back-Up Lead, since this is the connection from the radio to the battery that stores the time and your presets. If it is not hooked up, you can use the radio, but all your settings will return to default once you turn off the car. The Yellow Wire Bus Power Lead sounds like it would be for powering an auxiliary unit like a Sat Radio or HD Radio add-on. You will not need to connect this unless you have an add-on such as one of these.
Jan 29, 2009 | Clarion DXZ375MP CD Player
Antenna Power supply
First order of business is to check and see if the antenna is operating properly. If the wire in your harness is intended to power the antenna, connect 12 volts to this lead, and the antenna should go up (this needs to be done with the key in the ON or ACCY position). If the antenna does not go up, check the fusebox for a blown fuse. If the antenna does indeed go up, then you can scratch that off the list of possible problems and move on to the next step.
The Clarion should have a power input wire to keep the clock alive, and a power wire (normally of heavier guage) to actually power the radio. Make sure the radio operates when the key is in the ON or ACCY position. If the radio is operating, so far so good.
I'm kind of confused when you say there are two wires on the clarion... "power antenna turn-on" and "auto antenna". Are these both on the clarion? There should be a wire that constantly feeds the antenna with power (I would cal this one auto antenna). It should always be powered to 12 volts. The antenna should operate when the "antenna turn on" lead becomes 12 volts. Normally this ONLY happens when the clarion RADIO is on (ie: if you're listening to a CD, the antenna probably won't get activated).
After checking all this, if you're still having problems and if you haven't already done so, grab a DC volt meter and verify that the clarion power antenna turn on lead goes to 12 volts when you turn on the radio. If it does not, then there is an internal problem within the radio. If this lead IS going to 12 volts when it is supposed to and the antenna still isn't working, then my guess is that the antenna is malfunctioning.
Let me know what you find out... I'll keep looking at stuff from this end. Good luck.
Apr 19, 2008 | Clarion DB175MP CD Player
Installation
i suggest getting a wire harnees kit from an auto supply shop{pep boys,autozone,)the wire are usually color coded.also try going to to clarions support site they probably have a diagram 4 u.if not get back to me and ill tell you how to test and discorer what wire is what.if you connect wrong wire you can burn out your radio
Jan 21, 2008 | Clarion DXZ945MP CD Player
Clarion DXZ838RMP Installation guide
here's the insatllation guide; http://www.clarion.com/gb/en/MungoBlobs/423/180/DXZ838RMP-EU.pdf It is very detailed and has i think all the wiring info you would need :)
Apr 15, 2007 | Clarion DXZ838RMP CD Player
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
