Question about Krups Small Appliances Espresso Machine
Krups type 897, nespresso: Water leaking from top of pump. I've opened the back of machine and found that when the pump starts the water is shoting out at the join to the clear hose. The leak reduces when I hold in the hose in but I can't see how it should be held in.
  • bannister366 May 20, 2009
    Water is leaking down the pipes. This can be seen when I take the tray out. How do i open the machine to get to the pump and check the leak?
I swaped the hose around.
The o-ring at the element end is bigger and can be held in properly by the clip at the pump end. The bracket/clamp at the element end holds in the smaller o-ring sufficiently.
Posted on Oct 14, 2008
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
I need a user manual for a Krups 897
http://www.coffeemachinemanual.com/krups-f-897
Aug 01, 2014 | Krups Coffee Makers & Espresso Machines
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Krups XP2070
if the water is leaking from the back left side of the unit then the seal/valve to the expresso water container is lose and leaking. you can either go the warranty route or open the back up and tighten the two screws holding the seat/valve in place.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water won't flow out of espresso machine
Did you check to see if the heating element is not open?
Sep 09, 2017 | Krups XP 4050 Espresso Machine
Leaking water, does not close
I had the same problem with the nespresso krups xn20 machine. After calling the Nespresso service desk they substituted free of charge the water tank, which has a little valve with seal at the bottom. It turned out that the problem was not the seal of the water tank, but the seal of the machine (onto which the water tank is installed).
I solved the problem by using Teflon tape (same type as that used to connect for water pipes) on the water tank, applying it at the appendix which goes into the machine.
It's been working ok since then (couple of days). The only problem could be the wearing-off of the tape after some time (you will have to reapply it).
Apr 17, 2008 | Nespresso C100B Essenza Single-Serve...
Krups Small Appliances Espresso Machine Logo
1,264 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
