Question about Funai PY90VG DVD Player/VCR
Funai dvd/vcr combo B2735
On insertion of dvd (record mode) error message appears on screen after
about 30 seconds,error code 03-51,your help would be much appreciated
Thanking you
Laurie Hello, I have just purchased (eBay) the "Funai DRV-B2737" vcr/dvd recorder to transfer my videos. The machine won't record onto a DVD-RW blank disc. The on-screen message says "can not record on this disc",
Recording Error E4 54037380 . Can you offer me the solution, please. (spent hours on this already)!
  • 4 more comments
  • ellistomos Oct 11, 2008
    Funai DRV-B2737, I CAN NOT RECORD FROM VCR-DVD.
    What does the Error code E4 54037380 mean.
    What can I do to make this machine record (dubbing) from vcr-dvd, making it record onto a blank DVD-RW disc.
    Sometimes during the process a circle with a line through it appears at the top right-hand corner of screen.
  • Anonymous Mar 11, 2014
    freezes printing
    i need a manual
    Digital signals tunes in but loses picture
    on with remote indoor on but after 3 minites going for timer led blinking outdoor unit not running
  • Anonymous Mar 14, 2014
    i have the model funai drv-a2631 and i have not the original remote control,so how i can finalize the dvd?
    President:
  • 2,712 Answers
Try using a different DVD disk. Maybe a DVD+RW or a non-rewitable disk. That should resolve the issue. Check your product manual to find out which types of media are compatible with your unit.
Posted on Oct 11, 2008
    Brigadier General:
  • 6,966 Answers
Based on your description, the possibility is that the DV D recorder is not recognizing the blank disc. Things that cold be tried:
  • lens cleaning as ginko has posted; or
  • use a DVD-R;
  • change brand of blank disc; and/or
  • try a lower rated (speed) of blank DVDs.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Sergeant:
    Champion:
  • 331 Answers
I think there must be a daulty with the ...disk
because that has a bigger probability........
  • Funai Master
  • 19,396 Answers
Try cleaning lens first.
  • Ginko
    Ginko Oct 11, 2008
    That probably means you have a lens problem.
    Use a dvd lens cleaner kit , like the ones that you see clicking here.
    If
    that does not work, you will need to take apart the unit, access the
    lens pickup, and clean the lens directly, using isopropyl alcohol and a
    cotton sticks.
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Can i override the copy protected vhs tape to copy to dvd using the Funai Dvd/Casstte recorder HDR-B2735
There are ways around macrovision, but you would have to spend money on a box of tricks and you would have problems copying using the DVD/Cassette with it. Some computer programs will get rid of it, but again you would have to spend money to connect the VCR to your computer. In the end I have found it cheaper and less time consuming to purchase the DVD. Plus it will be better picture quality, aside from the fact that copying such an item is against the law.
Apr 05, 2010 | Funai PY90DG DVD Recorder
Will not record all I get is Error 3-51
I had a similar problem, it turned out the first time I tried it I didn't have a DVD in the tray! Then I found I was using a DVD+R blank DVD and this machine needs DVD-R DVD's. It certainly solved my problem using the right blank disc
Jul 13, 2009 | Funai PY90DG DVD Recorder
Funai WV20V6
VCR section seems have error in mechanism like incomplete loading of cassette, no spin of video head motor, high spin of capstan motor etc. You can observe above symptoms and let me know for further help.
Sep 13, 2008 | Funai FDRV90E DVD Recorder/VCR
FUNAI B2735 DVD/VCR COMBO
Have you tried a blank DVD with lower speed say 4X? Or for that matter, some other brand of blank DVDs?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Aug 28, 2008 | Funai PY90VG DVD Player/VCR
Funai DVD/VCR Combo (Model HDR B2735). Error message '03-56 Recording Error' Am unable to format DVD's
I had this error and fixed it by cleaning the lens and blowing all dust from the circuitry.
Paul
Aug 09, 2008 | Televison & Video
Funai HDR-D2835 or HDR-B2735 region unlock
i think the codes from phillips machines work.
try at your own risks tho
Jan 29, 2008 | Funai PY90VG DVD Player/VCR
Funai PY90VG DVD Player/VCR Logo
646 people viewed this question
Top Funai Televison & Video Experts
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
