Question about Garmin Nuvi 660 GPS Receiver
310 nuvi will not lock on to satellites - Garmin Nuvi 660 GPS Receiver
    Problem Solver:
  • 10 Answers
Hi
I think you need a replacement aerial assembly (we have them in stock)
see Ebay.co.uk and search for Garmin Repair for the best value all in Garmin Nuvi fix anywhere!!
Review our Ebay feedback!
MGA-TRADING
Posted on Dec 13, 2008
  • Garmin Master
  • 2,130 Answers
Please try this solution that helped someone else. If it doesn't help you then your antenna/receiver is defective and needs to be replaced. The antenna on the 310 & 360 are the same.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
- Jim
Posted on Oct 11, 2008
Can i get free up dates on maps on gamin nuvi 310
The only time garmin gives free map updates is if a new map becomes available within 60 days of the first time your satnav accesses satellites. If you think you're entitled to a free update go through the update procedure as described at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps If there's an update available click on get update. If you're entitled to it free it will bring you to the download page. If you're not entitled to it free it'll bring you to the payments page.
Feb 20, 2011 | Garmin nuvi 310 Car GPS Receiver
My screen for my garmin nuvi 310 has cracked i
not worth it, as the cost will exceed the unit value as the 310 series is obsolete, get a new one on ebay
Dec 06, 2009 | Garmin nuvi 310 Car GPS Receiver
For got my pin code for my garmin 310 . how doi
Give it back to the owner. Owners don't forget PIN and they also know the secret location where the unit will unlock itself without the PIN.
Nov 03, 2009 | Garmin nuvi 310 Car GPS Receiver
My Nuvi 310 can't find satelites.I have re-booted several times but without any Joy.the re-boot also locked on the map display The Mall in London.!?
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there
while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings. This will clear some of the memory allowing your Nuvi to collect new satellite data. Your Nuvi should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
Make sure the antenna is up and that you are outside. On the main screen, you will see a satellite bar graph in the upper left-hand corner. Touch the bar graph and you should get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you should see horizontal hollow bar graphs appear on the right. Eventually they will turn solid blue. This indicates they have downloaded the proper data from the satellite. When you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin to show improved accuracy and your Nuvi will then work as it should. This entire process make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you severl minutes later, if you are indoors. If your outside, select no. It will then ask you if you have moved 1000 miles since your last use. Select yes. This will cause your Nuvi to start looking for
satellites, trying to locate your new position.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no longer use its internal antenna and it's now always looking for an antenna at the external antenna port (the gold connector on the side of the Nuvi antenna). If you have a piece of small wire, a couple feet long, you can insert that into the center lead of the external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes and your Nuvi will lock.
I haven't been able to identify yet, which part has failed. I am working on that.
However, if the piece of wire works, you can always go on eBay or a retail store and
purchase an external antenna for your Nuvi. They are magnetic and can either stick to your roof or any metal surface within your vehicle.
Here's another way to determine if your antenna has failed and will have to be replaced:
At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then press "about". There is a field marked "GPS S/W". There should be a number next to it. It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS is communcating with the antenna receiver. If you see "0.0" then your antenna is defective and there's no way to repair it other than replace it.
Please let me know if I can be of further assistance to you.
- Jim
Nov 06, 2008 | Garmin GPS
Garmin 310. Bought March 2007, working perfectly until 1100 yesterd, then kept losing satellites, then coming back and so on. By 1200 lost all satellite connection. Satellite screnn shows no activity...
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this.
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Nov 03, 2008 | Garmin GPS
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Same here - garmin nuvi 310 - bought it last year around March, said dowloading gps and then can't get a signal/satellite?? Will phone garmin tomo
Apr 18, 2008 | GPS
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Sat stuck on one spot
Can you still access the menus or has it locked up totally?
If it has locked up totally, there is usually a tiny recessed reset button that you can press to restart. failing that, try holding down the power button for 10 seconds
Then take it outside somewhere where there is plenty of clear blue sky and turn it back on again. It might take a while to get a good satellite lock, but it should come back.
Sat Nav systems do not work well indoors, which is where most people want to test them.
Jan 13, 2008 | Audio Players & Recorders
Garmin Nuvi 660 GPS Receiver Logo
250 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
