Question about Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS System
Ups repair my ups is not giving adicuate back up even my betteries volt are 12.56v.it will give only 10 sec backup.please tell me any salution.
  • 74 Answers
First Larn some English (rofl) Then try replacing the batteries,
Posted on Oct 11, 2008
Apc smart ups rt 10000 internal fault, what will cause it?
if you can give me the source code I can tell you. the code is going to be in the form of zero's and one's
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
I have APC SUA1000I and attach two batteries par battery 90Amps but battery is not of APC company and i have calibrate the ups but its not working the battery gives 25mints backup hardly and the software...
You need to make sure that you are installing (2) 12 volt, 12 amp hour batteries... as long as they meet those specs then the battery manufacturer matters little. I recommend CSB, MK, or Werker batteries. You can find them for 56USD.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Aug 04, 2013 | Computers & Internet
Low output voltage in apc ups cs500
is that 165 Volts AC or DC? Try to reset the logic. Unplug the UPS from the wall and disconnect the batteries. Push the "On Button" The LED's may flash. This is resetting the logic. This migh help. This should be 120VAC in and 120VAC out. Please give me an update.
Oct 31, 2011 | Computers & Internet
My mercury radiant 1000 inverter dose not give backup time. although my battery is new.and also tell me the salutation of increase the charging.give answer urgent pleas.
Dear, Please check following
1. Are you using correct gauge of wire for batteries (Specification mentioned in the manual)
2. You need to charge your batteries at least for 8 hours (as recommended by Mercury)
3. Please place your Inverter in a cool environment (20 to 30 C)
4. Nominal voltage of battery should be 12Volt if using 1x Battery.
Regards.
Oct 11, 2010 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
My emerge UPS 500 is not at all giving backup.. its stays only for 1min after power goes.. before it had given more than 10 min but now it not even stands for 1 min.. pls help me.. wat i have to do??
you need new batteries,
then i think all will be back to normal.
WARNING
ups batteries are very dangerous, always seek the advice of a good tech or electronics shop.
Hope this helps
Thanks for using FixYa
Oh! please vote if useful
Aug 09, 2010 | Compaq R1500 ( 295459-001 ) UPS...
Even though we have put fresh batteries in, it turns off saying "low bettery"
Hello
Thank you for using FixYa for your problem
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Praktica DCZ5.0 Digital Camera
When i connect 4 batteries in series for a total of 55 Volt, the ups tells me there is a problem with my battery. is the ups overcharging my battery or are the batteries overcharged. i bought them with...
I think UPS' are supposed to run on 12 volt batteries. You must connect them in parallel and not ie series as you are doing now. Connect all the Positives together and all the negatives together to give 12 volts and four times the amperage of each battery for longer backup. With series connection you may burn the system. Please check the manual that came with the UPS.
Nov 17, 2009 | Powercom King Pro 3000VA...
Test/Troubleshoot APC Battery Backups
All batteries, old or not really used hard should be replaced every three years. If not they turn to acid, or blister. If bllister does occur, throw the unit away, most likely the inverter will not last very long after the new batter is installed.
To know if your UPS is working right even if the battery might check out, use a volt meter to see if the battery is 12.5 to Volts. If you have a ceramic 10 ohm resister, you can alagator clip it across the + & - and it should hold the voltage above 12V DC, but if it sinks real quick below that...that battery is done.
To check to see if your UPS is OK. Plug it in use the volt meter to check the output voltage. Should be 115V-120V AC, unplug the plug from the wall socket and the readings should be hovering around 118V AC. That means your Inverter is still working. If the UPS dies, two things, go check the battery, or the inverter is toast-Throw away the Unit buy another. May I suggest that since CPU's are getting more advanced and faster and new computer power supplies are getting bigger go bigger on the UPS. Start out with a 1000VA or standardize on 1500VA. They really are not too expensive like they use to be.
check out my web page, should give you an idea.... http://www.storminprotection.com
Aug 11, 2009 | APC Back-UPS CS 500VA UPS System
Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS System Logo
210 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
