Question about Brother MFC-665CW All-In-One InkJet Printer
Mfc-665cw all in one paper tray
How do i remove the paper tray in order to refill it?!
  • holly1207 Oct 13, 2008
    I'm not going to pay to fix a problem that shouldn't exist!
    Problem Solver:
  • 12 Answers
To get the paper tray out, remove the rear "door "from the all-in-one (and "carefully" lift the roller guide out of the way. Sometimes a finger works, but a pen is guaranteed to work. When the roller guide is out of the way the tray slides out verrry easily. When its not, the tray is nearly impossible to get out!
Note that the right-hand side of the tray has two inclined guide "ramps" that work as the tray is removed. Once you get the tray out place a "small!" amount of petroleum jelly on the rear ramp: works like a champ.
Posted on Aug 25, 2009
  • 286 Answers
The tray is very easily removed. Just grab it and pull. If you cannot get it out, there may be damage to the paper pickup roller assembly preventing you from pulling it out. Open the rear jam-clear door and inspect the roller from the rear.
The trays are so easy to pull out that if you cannot get it out, it likely has some damage preventing it from being pulled out.
Try dropping by the store you bought it from and have a look at the display model. If you cannot open the tray of the display unit, have a salesman assist you.
Posted on Nov 04, 2008
MFC-665CW won't turn off?
Brother MFC-665CW Quick Start Manual - ManualsLib
www.manualslib.com > ... > All in One Printer > MFC-665CW
View and Download Brother MFC-665CW quick start manual online. Brother MFC-665CW: Quick Start. MFC-665CW All in One Printer pdf manual download
Aug 30, 2015 | Brother MFC-665CW All-In-One InkJet...
Paper tray: Feeder won't work
Do not know brand of paper, but shcek to see if feed wheels are turning when you try to feed. If wheels are turning than they are either dirty, clean with soap and water. or the whells need replacement..
Sep 30, 2013 | Brother MFC-665CW All-In-One InkJet...
Im getting unable to print 50 error on my brother mfc 665cw
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
I'm getting an error saying Unable to print 30
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 17, 2009 | Brother MFC-665CW All-In-One InkJet...
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
Paper jam
For this and any other print jam problems try this;
Open the scan bed tray and push down the button at the front (scan bed tray open switch)
I found if your print jam occurs and you go through this procedure, the jam clears itself.
With the tray still up and switch held down, try and print something.
See how far the paper goes through the print cycle before jamming. If it jams when it reaches the print head...clean under the print head and try again.
Hope this helps
Mar 17, 2009 | Brother Multi-Function Center MFC-665CW...
Paper jam
give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Brother MFC-665CW
I need a manuel, I'm trying to print a 4 x 6 picture and when I take out the regular 8 x 10 copy paper and want to put in the 4 x 6 picture paper I don't know where to put it. I can print a 4 x 6 on regular copy paper but thats not what I want.
Dec 20, 2007 | Brother Multi-Function Center MFC-665CW...
Brother MFC-665CW All-In-One InkJet Printer Logo
227 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
