Question about Samsung HCL4715W 47" Rear Projection Television
Red a green shadows on most objects!
Most of the time when watching this TV like say golf all objects have a red and green shadow. Thanks Eddie
  • ejcjr Oct 18, 2008
    Thanks for the info
  • yschoice2003 Nov 03, 2008
    We have pink and green shadows and when looking at picture it looks like we're looking into a globe. how do we fix this. we have hlp4663w 46" rear projection tv.
    Problem Solver:
Use manual convergence to re align the colors. the owners manual tells you how to do this. No manual go to samsung. com in the FAQ section
Posted on Oct 17, 2008
On the screen there is a green shadow on one side and a red shadow on the other side of every object in the scene
This tv has two big black ICs as convergence output on deflection circuit board that are defective and causing problem in tv, IC number is STK392-110
replace both ICs to solve tv problem, also chekc for faded color big resistor nearby these ICs or those got burn mark, replace these resistors with same value, aslo check cold/ dry solder joints in deflection circuit board and resolder these joint/ connections.
Thanks.
Jan 21, 2011 | Hitachi 65TWX20B 65" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Red, Green, and Blue shadowed lights
the lense red blue green is warped you will need to replace those lenses
Aug 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Red & green shadows have started to appear on all images similar to 3D broadcast.
The convergence integrated circuits have failed. It can be fixed-about $350.00
Apr 15, 2009 | Televison & Video
Red shadow on tv
If this is a projection tv a shadow usually indicates bad convergence. If you cannot adjust convergence from customer menu have a professional replace convergence amplifiers and reconverge
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green shadows around small red objects (football players with red shirts)
turn tv of by power point for 1 hour then switch back on that resets the picture if still happens may need a service
Jan 27, 2009 | RCA HD61LPW164 61" Rear Projection HDTV
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Sony kdf-e50a12u rear projection lcd bravia. red...shadows
try this http://www.avforums.com/forums/showthread.php?t=459681
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
104 people viewed this question
Henry  Thomas
Henry Thomas
