Question about Nokia N95 Cellular Phone
N95 receiving message
Why is my phone if sumone will call me the name will appear because its in my phone book.. but if they will message me only number is appearing. its also in my phone book
  • ronelazaro Oct 12, 2008
    i did already but same thing happened. still the number is only appearing if i will receive the message. but that nuber is on my phonebook... but if they will call me... the name is there please help thanks
    Master:
  • 383 Answers
There might be a bug in the software . Backup all of your phone memory . and Contacts and messages etc. Then reset the phone by typing *#7370# .... default code is 12345. the phone will restart . Restore the backup taken and check.
Posted on Oct 12, 2008
  • Parshiv Luthra Oct 12, 2008
    Kindly upgrade the software of your cell from nokia and try again
My motorola razr does not display the names when i receive text messages
check the phone book entries...possible the names are appearing twice in the phonebook...or the format in which nos are saved could be diff from the format of numbers u get message ...eg : u might have stores only no and when u recieve msg it might come with a 0 or country code too
Feb 11, 2012 | Motorola Mobility RAZR V3
Phone book names are not always appearing when receiving calls
Check may be you have saved names on phone aswell as sim.
So delete some name in "sim" memory and check.
  • On the Home screen, click Address Book.
  • Open the menu and select SIM Phone Book.
  • To delete an entry, highlight it, open the menu, and select Delete.
  • When the Delete Phone Book Entry? message box appears, click Delete.
Nov 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
I have a nokia n95-1. I have copied sim contacts to the phone which have duplicated when I synchronised with Outlook. I can cope with that. What I dont understand is why the numbers of any of my contacts...
When you receive a phone call, the phone will look up in it's address book to see if it can find a match for that number, if there is only one match, great, it will display it, if there is more than one match, it would be difficult for the phone to 'guess' at who is calling, so instead it just displays the number.
First make sure you do not have duplicate Entries for the same number.
I would suggest you to do the following:
  1. Make sure you have copied all the contacts from your SIM to Phone
  2. Delete all the Entries from your SIM by selecting them at once
  3. Make sure you do not have any Duplicate Entry in the phone book
  4. If you suspect having duplicate entries, Sync. the phone with Outlook and search for Duplicate entries to delete them
Please make sure you have selected the default memory as SIM and Phone. If you have stored your contacts in the Address book of your Phone memory and selected the Sim card memory as the default phone book it is obvious that when receiving a call your phone will try to look for that number in the default memory selected by you or vise-versa.
Go to phonebook > Settings > and select the memory in use as Phone and SIM
Hope it is not confusing
Please get back for any clarification
Thank you for using Fixya
Oct 08, 2009 | Nokia N95 Cellular Phone
Is there any way to make the persons name appear for a text
It should be as simple as adding their name and number to the address book on the phone.
Make sure to list the number under the Mobile Phone line.
While in the address book, there is usually a line that says "New Entry" or "Add number" etc...(without the type of phone I cant get specific).
Another method is to into the text message itself and do an options click (again without the phone cant be specific) and there should be an option to add the number to the address book.
Aug 05, 2009 | Cell Phones
Lost sim card cant get my pin bk becuz sumone one change my pin number
The only way to get a lost pin number is by calling the phone company.
Put phone company name on google and give them a call, they are the only ones who can unlock the SIM card.
The only other way out is by replacing the Sim card, but that will also change phone number.
Apr 27, 2009 | Nokia N95 Cellular Phone
Trouble with contacts
Was your Sim card copied to the address book?
You may have to fix the entries copied from the sim card into the address book so that the cell phone number is in the correct field as well as the names. By default it may not be properly stored into the correct fields.
Mar 18, 2009 | RIM BlackBerry 8700c Cellular Phone
Can't see addressbook name when i receive a text message
That means that there is a double entry. the number saved in your address book has eitehr been saved twice or saved twice with different names. Delete the entry in the address book then turn off and on your phone. you should see the name of the other entry now.
Jan 05, 2009 | LG Shine KE970 Cellular Phone
N95 incoming caller id issue
you should try and add your contacts to your phone memory........remove the + from the number
Mar 23, 2008 | Nokia N95 Cellular Phone
N95 wont display names
I f u r able to transferr contacts to ur memory card then pliz do that and then reset ur phone and the default code is 12345, otherwise save ur conatacts on paper, then reset ur phone, and if u r using ur memory card then remove this and see whether the contacts appear or not.
Oct 19, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
