Question about Bosch Washing Machines
Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
  • Bosch Master
  • 19,396 Answers
That is probably a problem with the timer.
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Oct 11, 2008
    My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
    HI lisa
    Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
    May 25, 2016 | Washing Machines
    Hoover 500mb washing machine doesn't 'click' through the cycles
    Sounds like your timer is not working correctly. I would suggest replacing it, as there isn't a way to repurchase timers.
    Oct 10, 2015 | Hoover Washing Machines
    I have the Malber WD1000,the wash cycle goes on but no water pumps out, a couple drops come out . How do i fix it?
    No water fill
    1.water valves closed----turn on valves
    2. Hoses kinked---unkink hoses
    3. Screen in fill hose clogged----clean out screen
    4. No power to fill solenoid---replace solenoid
    5. Faulty water level control---replace control
    6. Machine did not turn on----check control & power outlet
    Water will not drain from machine
    1.kinked or clogged hose----clean drain hose
    2.pump does not run----readjust & tighten pump-drive mechanism
    3.suds lock----remove suds,, add cold water
    4.faulty transfer valve---replace
    5.defective timer----replace
    6.loose belt---adjust belt
    Sep 22, 2011 | Malber WD1000 Front Load Washer/Dryer
    Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
    Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
    Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
    Dec 26, 2010 | Washing Machines
    Fisher & paykel washing machine (gw603-u) emptys while filling
    Hi just read your posting.Now where is you machine draining to?Is it draining into the laundry sink or somewhere else?If it is draining into the laundry sink and not into a grey water hose then I am afraid it must be the green motor controller.This controller has the pressure switch as part of the circuit board.I think though it must be the fet that controls the power to your pump might be faulty.Are you in Australia as there are company's that will test your motor controller if you send it to them.Please reply with additional information and I can help you further.
    Jul 08, 2010 | Fisher and Paykel Washing Machines
    Zanussi jet stream iz16s tripping ouy rcd once filled up with
    It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
    Good luck
    Mar 17, 2010 | Washing Machines
    Washer won't drain.
    My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
    Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
    WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
    not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
    Oct 07, 2009 | Roper RAS6233KQ Top Load Washer
    Washer won't wash
    Hi!
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 30, 2009 | GE Washing Machines
    Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
    You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
    Dec 21, 2007 | Admiral AW22 Top Load Washer
    Washing Machines Logo
    355 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Richard Roth
    Richard Roth
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
