Question about Miele K8452S Refrigerator
Freezing up Evan on the lowest setting, anything left on the bottom shelf freezes up! It's only a fridge without a freezer nothing is supposed to freeze! Could it be the thermostat?
  • 30 Answers
Primary Cause is Thermostate
Secondary Cause only Anti Freez Switch which is attached to the Evaporator Coil unit
Good Luck
Posted on Feb 16, 2009
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Freezer and Fridge too cold
You will need to replace the control board. Here is that part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 21, 2013 | Refrigerators
The Fridge Section is freezing even though I have the frisge settings on the lowest setting! Jeff Malley 0402 004405 Rye Vic.
I have this same issue on a C410B, also located in Rye .
I think its a thermostat issue, unless yours is freezing only on the bottom of the fridge (which could be a fan circullation issue)
Jan 01, 2011 | Fisher and Paykel Active Smart E522B...
Freezer set at 0 fridge set at 37. thngs in fridge and crisper are freezing
this is a big problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Kenmore 73503 Stainless Steel Bottom...
MFD2560HEW Bottom freezer french doors. Top shelf in fridge is 52.2 degrees 2nd shelf is 45.7 degrees 3rd shelf is 38.5 degrees and the bottom shelf that slides out that sits above the freezer is freezing...
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Jun 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Top of the freezer not freezing
SealedSystem problem. You need a "Certified Technician".
Apr 26, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Miele K8452S Refrigerator Logo
511 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
