Bought new cartridge and the light is flashing after insertion, consequently cannot print and cannot use the trial print, any ideas anyone?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check your cartridge it must come with a cellphane or stripe of nylon which you must remove before inserting it into your printer
Posted on Oct 11, 2008
How do you load new printer cartriges
To replace an ink cartridge using the fonth.gif ink button, follow the steps below.
1. Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
2. Lower the output tray, then open the printer cover.
3. Press the fonth.gif ink button. The print head moves to the ink cartridge replacement position, the fontp.gif power light begins to flash, and the fonth.gif ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
4. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it.
5.Remove the new ink cartridge from its protective bag. Place the ink cartridge vertically into the cartridge holder. Then, push the ink cartridge down until it clicks into place. Do not apply excessive force to the cartridge.
6. When you are finished replacing the cartridge, close the cartridge cover and the printer cover.
7. Press the fonth.gif ink button. The printer moves the print head and begins charging the ink delivery system. The fonth.gif ink lights start flashing. This process takes about one minute to complete. When the ink charging process is finished, the printer returns the print head to its home position. The fontp.gif power light will stop flashing and remain on, and the fonth.gif ink out light will turn off. The fontp.gif power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
Nov 19, 2010 | Epson Office Equipment & Supplies
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
Canon PIxma ip2600 not printing
Hi
Maybe that the chip itself is faulty. I would take back and ask for a replacement.
Taz
Nov 09, 2009 | Canon Pixma iP2600 Photo InkJet Printer
New yellow toner not fitting properly
try to install the cartridge again and see if it can print.or u can reinstall the printer drivers. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Samsung CLP 300 Laser Printer
Red light on Flashing green light
I just got a new unit and it came with three defective ink cartridges - go to printer, right click, select Preferences and the window that pops up will have the cartridges illustrated with an X on the defective one. Epson replaced my defective cartridges at no charge - just the inconvenience of waiting for delivery.
Dec 15, 2008 | Epson Stylus Photo 1400 Printer
Ink button flashes,with new ink cartridges, doesn't load or print
You may have damaged or punctured the Print Head. Please remove the cartridge and inspect. i think Replacement of the damaged cartridge is the resolution.hope this helps .Goodluck thanks and Godbless
Dec 15, 2008 | MicroBoards PF-2 InkJet Printer
Just bought an HP Photosmart C7280 and am going thru initial set up. Have got to the stage where insert paper which should then run trial page before i then move onto the wi fi set up Unfortunately the...
Where did you buy the printer? Was it new? If you bought it from ebay, the seller has provided a new set of initialisation inks with a used printer. These inks only work with a printer which is brand new and completely unused. They mix with ink already in the system on first use and they cannot be used with another printer and cannot be used in a printer which has already gone through the initialisation process. There is however a work around. Let me know if you need it
Nov 30, 2008 | HP Office Equipment & Supplies
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
65 people viewed this question
k24674
jasbo
jasbo
