Question about Miscellaneous
I just installed my o/r h pipe on my 97 cobra..exhaust leak?
So i just installed my o/r h pipe on my 97 cobra...and i believe i have a leak in the passanger side where the h-pipe connects to the manifold.....i dont wana take apart again...but do u guys think that exhaust shops could fix the leak with like a fitting, cuppling or somthing in that nature....sounds nice but when u have the foot the peadal u can hear like air rite there...its anoying wat do u guys think...thanx for help
  • 3,052 Answers
Hello AbdulRahiman S,
You are absolutely correct...
I have been to exhaust shops where magic tricks
were performed in STAINLESS STEEL...
Weighed against the alternative of BRAIN DAMAGE
or WORSE from toxic fumes...
I don't think you have any choice...
Especially if you are tired of the hassle...
You are SMART to get a seasoned PROFESSIONAL
to configure an ELEGANT solution.
Happy motoring...!!
Carnac the Magnificent
Posted on Jun 20, 2017
    Top Expert:
  • Miscellaneous Master
  • 48,355 Answers
Ake it to an accredited exhaust shop and have it fixed properly
Location of thermostat on 2002 olds alero 2.2
Thermostat Removal & Installation 2.2L Engine To Remove:
  1. Remove the exhaust manifold. If equipped with an automatic transmission.
  2. Drain the cooling system.
  3. Remove or disconnect the following: chevy_cav_02-04_tstat.gif
    • Thermostat housing to water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
    • Thermostat housing to water pump feed pipe.
    • Thermostat.
To Install:
  1. Install or connect the following:
    • Thermostat.
    • Thermostat housing to water pump feed pipe bolt.
      1. Tighten bolt to 89 in lbs (10 Nm).
    • Exhaust manifold if equipped with an automatic transmission.
  2. Fill the cooling system.
2.4L Engine To Remove:
  1. Drain the cooling system.
  2. Remove the exhaust manifold heat shield.
  3. Remove the coolant inlet housing mounting bolts through the exhaust manifold.
  4. Raise and safely support the vehicle.
  5. Remove the coolant inlet housing stud from the oil pan.
  6. Remove wheel and tire assembly.
  7. Remove the engine splash shield.
  8. Remove the mounting bolts from the transaxle-to-engine block support. Remove the support.
  9. Remove the coolant housing pipe.
  10. Remove the thermostat.
  11. Clean the mating surfaces.
To Install:
  1. Install the thermostat.
  2. Install the coolant housing pipe.
  3. Install and secure the transaxle support-to-engine block mounting bolts.
  4. Install the engine splash shield.
  5. Install the wheel and tire assembly.
  6. Install the coolant inlet housing stud to the oil pan.
    • Tighten to 19 ft lb (26 Nm).
  7. Lower the vehicle.
  8. Install the coolant inlet housing bolts through the exhaust manifold.
    • Tighten the coolant inlet housing bolts to 10 ft lb (14 Nm).
  9. Install the exhaust manifold heat shield.
  10. Fill the cooling system.
  11. Inspect the system for leaks.
3.4L Engine To Remove:
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat.
To Install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts.
    • Tighten the thermostat housing bolts to 18 ft lb (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet.
    • Tighten the fittings to 15 ft lb (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks
Oct 14, 2010 | Oldsmobile Alero Cars & Trucks
I have a 97 kia sportage. I think i have a exhaust leak. can that have the check engine light on? AND is that the manifold that need to be fixed?
Yes it will turn on light. Replace exhaust manifold only if it is leaking. It could just be loose or damaged gasket or hole or crack pipe.
Jan 21, 2010 | 1997 Kia Sportage
How do i change a water pump in a 97 grand am with a 2.4 litre engine
2.4L Engine
See Figure 3
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Disconnect the oxygen sensor wiring.
  4. Remove the upper exhaust manifold heat shield.
  5. Raise and safely support the front end of the vehicle securely on jackstands.
  6. Remove the exhaust manifold brace bolt.
  7. Unbolt and remove the lower exhaust manifold heat shield.
  8. Break loose the manifold-to-exhaust pipe spring loaded nuts.
  9. Unbolt the radiator outlet pipe assembly from the water pump cover.
  10. Disconnect the exhaust pipe from the manifold.
  11. Pull down and back on the exhaust pipe to disengage it from the exhaust manifold bolts.
Do not rotate the flex coupling more than 4°. this could damage the component.
  1. Separate the radiator outlet pipe from the oil pan and transaxle.
    1. On manual transaxle, remove the exhaust manifold brace.
  2. Next, leave the lower radiator hose attached and pull down on the outlet pipe to detach it from the water pump. Allow the outlet pipe to hang.
  3. Lower the vehicle.
  4. Remove the exhaust manifold-to-cylinder head nuts.
  5. Extract the manifold, seals and gaskets.
  6. Remove the timing chain cover. Refer to the procedure later on in this section.
  7. Remove the timing chain tensioner. Refer to Timing Chain removal later in this section.
  8. Unbolt the water pump from the cylinder block.
  9. Extract the pump assembly-to-timing chain housing nuts.
  10. Remove the water pump and cover assembly.
  11. Separate the pump from the cover.
  12. Clean all mating surfaces of gaskets and sealant materials.
To install:
Prior to installing the water pump, read the entire procedure. Pay special attention to the tightening sequence to avoid component damage and ensure a proper seal.
  1. Attach the water pump to the cover and hand-tighten the components.
  2. Lubricate the splines of the water pump drive with chassis grease or equivalent, then install the pump and cover assembly. Hand tighten the cover-to-block bolts.
  3. Install the pump-to-chain housing nuts and hand-tighten.
  4. Lubricate the O-ring on the radiator outlet pipe with an anti-freeze solution and slide the pipe into the water pump cover, install and hand-tighten the bolts.
  5. With the specified gaps, tighten in sequence as follows:
    1. Pump assembly-to-chain housing nuts
    2. Pump cover-to-pump assembly
    3. Cover-to-block, bottom bolt first
    4. Radiator outlet pipe assembly-to-cover
  6. Install the exhaust manifold using new gaskets.
  7. Install the manifold-to-cylinder head nuts, follow the tightening sequence and tighten to specifications.
  8. Raise and support the front of the vehicle.
  9. Index the exhaust manifold-to-exhaust pipe flange bolts.
    1. Turn bolt bolts in evenly to avoid cocking the exhaust pipe and binding the bolts. Turn the bolts in until they are fully seated.
  10. Install and secure the radiator outlet pipe to the transaxle and oil pan.
On manual transaxles, install the exhaust manifold brace.
  1. Install the timing chain tensioner and chain cover.
  2. Attach the lower heat shield.
  4. Attach the exhaust manifold brace. Tighten the manifold-to-exhaust pipe nuts to specification.
  5. Attach and secure the upper heat shield.
  6. Connect the oxygen sensor wiring.
  7. Fill the radiator with coolant water mixture until it reaches the heater hose coolant outlet, then install the hose and continue to fill. This will assist with the complete cylinder block fill.
  8. Connect the negative battery cable.
  9. Start the engine and top off the cooling system and check for leaks.
Dec 28, 2009 | 1997 Pontiac Grand Am
I have a leak in my exhaust pipe but my catalytic converter is fine and the toyota dealer wanted me to replace allof it for $1200. I think this is unneccessary why not just fix the hole. I want to take it...
do the second option , there is no need to change the cat. its working perfect , and this is whats the most expensive iten on the exhaust , the dealer is the most expensive place to go anyway , isnt they an exhast and tyre centre to go to for a second opinion .
1200 buck is far far to dear when its just a hole , plus i know the cat can be removed and reused on the new pipe if neededs
teryy from . uk.
Nov 21, 2009 | 2001 Toyota Camry
My motorcycle came with Cobra pipes and these are
Im not very familiar with your specific bike, but I do know what your problem is.cobra pipes are usually a straight-through design, meaning they have no muffler. the ones that do have a muffler usually have a very small one. smaller mufflers mean less fiberglass packing inside to absorb all of that noise. if your not too concerned about performance, then your best bet would be to go back to a factory exhaust. thats going to be the quietest one that you can use. Im sure there are also aftermarket systems available that also use a good muffler for noise control, but pretty much any aftermarket pipe is going to be louder then the factory setup. they are designed to give your engine more performance, which means less restriction for the xhaust gasses, which also means more noise due to the more open design of the pipes. Im not sure if your bike comes carbureted or fuel injected, but keep in ind that any exhaust changes made to a carbureted engine will require carburetor jetting adjustments to compensate for the change in exhaust flow. now, if you decide that your willing to lose just a tiny bit of performance for a quieter ride, then you may be able to find a used stock system on ebay for a very reasonable price. or if you want to stay aftermarket, then most companies test the sound levels of their exhaust pipes. by contacting the manufacturers, you should be able to obtain and compare the sound decible levels for different exhaust companies to find one that meets your needs.
Jul 28, 2009 | 2002 Yamaha Road Star
How to pull out tranny and fix TO bearing on a 97 mustang v6. 5 speed thanks alex
start by removing the the shifter lever and boot, next remove the drive shaft,then remove clutch cable or hydraulic line for throw out fork,it may be neccessary to remove y-pipe and some of the exhaust using a transmission or floor jack support transmission and remove crossmember, remove bellhousing bolts and transmission should now be free to remove.
Jul 18, 2009 | 1999 Ford Mustang Cobra
Instructional manual on installing cobra exhaust pipes on a strat
You are looking for to buy a motorcycle or you need to install a new exhaust kit on a bike you already have?
I don't understand "strat".What brand and model is the bike?How many cylinders?
Jun 26, 2009 | Motorcycles
Miscellaneous Logo
32 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
