Question about HP OmniBook XE3 Notebook
What is a better software for omnia? spb...s2U2...or touch flo 2d OR CAN YOU INSTALL THEM ALL TOGETHER?
CAN you install them all together but use them one at a time?....or if you have any good skins for omnia can you please suggest them?...THANKS
2 of the things you mention SPB and TouchFlo 2d are user interfaces.
i have used both in the past and each has its positive and negative points.
SPB mobile shell gives the benefit of making your Omnia much more finger friendly. when i had this installed i really didnt have a use for the stylus any more.
where it falls down a bit is in the way different things work inside the shell itself.the basic omnia screen still runs in the background, then you have to touch the soft button in order to launch the mobile shell each time you reboot the phone. also if you hit the bottom right hardware button the screen reverts back to the basic samsung screen and you have to hit the soft button again to relaunch the SPB shell. if it had a bit more of a flowing feel to it i would have stayed with it but it almost felt clumsy compared to other user interfaces i have tried.
i am currently running the TouchFlo2d user interface and have to say i am quite happy with it. it is also known as Manilla2D. i followed the basic instructions here http://www.modaco.com/content/i900-omnia-rom-discussion/274737/update-24-nov-08-custom-rom-manilla2d-with-alternate-landscape-dxhk1-m2d04/ and have not had a single problem with it as of yet....been installed for 2 weeks now.
full install instructions are on that forum thread as well as a ton of different Omnia only themes you can install to change the look of TouchFlo to better suit your personality.
i dont reccomend installing both user interfaces at the same time unless you just basically want run out of internal software memory ( this is different then storage memory)
the 3rd app you mentioned is simply a screen locker.
S2U2 can be used with either of the above UI's but i found it, for lack of a better word, useless.
holding down the right lower hardware button for 3 seconds locks the screen anyhow. then it takes 2 taps to unlock it again.
if you are simply trying to emulate the slide to unlock on the iPhone then maybe you bought the wrong phone to start with.
other uset interfaces you might want to take a look at are winterface and pointui.
i have already found my fav but maybe your tastes are different.
good luck
Posted on Dec 09, 2008
Htc skin is pretty good
Posted on Nov 10, 2008
How can i install software on my phone samsung sgh-i900 omnia
you can either install softwares by downloading it from any sites,or by receiving from your friends.then direcly install it..
Nov 05, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
I AM UNABLE TO GET MY WET END PART # 91040840 DISCONNECTED FROM THE MOTOR SHAFT. WHERE WOULD I FIND SCHEMATICS PERTAINING TO THIS.
you will need to remove the back cover on the motor and the suction side cover to expose the impeller. You'll need to hold the shaft from turning and remove the impeller by turning counterclockwise. Some impellers will have a phillips head screw in the center, if so, you can remove it by turning it clockwise. Once the impeller is removed, you can loosen the through bolts and it will all come apart. You can install the new seal and reverse the process to put back together. Hope this helps.
Oct 29, 2010 | Aqua Flo AQUA-FLO #200 SEAL, REPLACEMENT -...
How to change analogue clock to digital in htc touch p3450
u cant change your clock.....download spb time software for your htc touch p3450 its a very great software for time....download .cab file in your phone memory card and install....here is the download link http://rapidshare.com/files/76304644/SpbTime2.arm.cab
following is the serial number to get the full version of the software
Serial:
21341317
24234523
73679292
13870673
61330463
72383490
Nov 12, 2009 | HTC Touch P3450 Smartphone
HTC Touch 3g clone (T3238) won't turn on, no lights, nothing!
Simply!
Power off the device, then hold the Volume Down and Enter buttons at the same time, then press the Power button.
A message should come up asking if you’re sure you want to do this, let go of the buttons you held down and press the Volume Up button to accept, or any other button to cancel the reset.
please note >> it is will delete all your data ...........!
Oct 05, 2009 | HTC P3300 Smartphone
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Touch screen not work no response after i made hard reset
You may follow the steps below to reset it to default factory settings.
Hard Reset will reset your Omnia back to Factory Default. All contacts and information you have put on Omnia will be lost. Please backup before proceeding.
1. Poke the soft reset hole beside your power button(Poke and Release)
2. Press and hold the Call and Cancel Button together(Do it immediately after Step 1)
3. Do not release Call and Cancel button, the Samsung Omnia Screen Appear
Press Call to Format or End Call to Cancel.
This hard reset does not erase the 16GB memory. To reset everything, you could use the software hard reset by going to Settings > Hard Reset. There is also option to format the storage card.
If you decided not to format and press cancel, that will soft reset the phone.
Aug 23, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Software wont work on vista
The omnia runs on windows mobile, so it sync through activesync, but I suppose you already know that.
To install software/applications onto the omnia, you have to install via the pc, IF the file is a supported .exe or .msi installation file to install the program components onto you PC.
If you have software in the form of a .cab file, it must be run from the omnia. So you have to go to My Computer>Mobile Device> and then put it in your phone, then from your phone, run the .cab file.
Basically, if it doesn't work on vista, put it on the phone and try running it through the phone. Also, if you dont know, you go to start>programs>file explorer (on the phone) to find the file and run it.
Feb 28, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Icontact by default on mi samsung omnia
why dont u try modding ur phone menu i mean change it to SPB mobile shell and then u can change the soft key or just set the hardware key on the right of the PDA used for menu u can customize it in settings and make it go for icontact then when u press that key it will bring i contact , or u can google there is software for changing soft keys and hard keys , i will not suggest playing with ur registry
Feb 02, 2009 | HTC Touch P3450 Smartphone
Samsung omnia 900i
Hi
This may be a codec problem. I resolved all my issues by installing Core media player.
http://www.10001downloads.com/software/the-core-media-player-1601.html
Its free and a better all round solution for sound or video on the Omnia. Easy to use and install - worth a go. You dont say what firmare you are running on the phone. There are now many "cooked" (customised) roms available for the Omnia with all sorts of facilities head over to :
http://www.modaco.com/category/342/i900-omnia-http-omnia-modaco-com/
for details, help and advice.
Have fun!
Sep 25, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
HP OmniBook XE3 Notebook Logo
5,144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
