Question about Kirby Vacuums
Kirby G series drive unit needs replacement. Where do I get a unit at the best price
    Problem Solver:
  • 9 Answers
Try eBay or Craig's List. You can get a lot of good deals for that model. I've looked, and there's deals for like $5 to $15.
Posted on Oct 11, 2008
Wont go in drive
Your handle bale could be bad, but I doubt it. I think you have a bad transmission. Buy Kirby Transmission Power Drive Unit 552399S Online at Best Price...
Mar 05, 2014 | Kirby Generation 3 Bagged Upright Vacuum
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
My Kirby G3 diamond series won't turn on
Hi There, The most common problem by far is that the cord is faulty. This is a pretty easy repair to do at home. If your machine was randomly cutting out before it stopped altogether then the cord is likely the culprit. If however it stopped all of a sudden with no warning then it is possibly a switch or motor issue which is a much harder repair to achieve for a novice.
The kirby cords are not terribly expensive (and I have linked a how to video showing how its done) so if you need a new one I would say DIY is the go, otherwise spend the $25 get a pro to take a look.
May 22, 2012 | Kirby Generation 3 Bagged Upright Vacuum
I NOTICED SPARKS INSIDE THE UNIT WHERE THE HANDLE ATTACHES TO THE MOTOR....NOW IT IS NOT WORKING WHAT CAN THIS BE?
DO NOT TRY TO TURN THE KIRBY ON ANYMORE BEFORE YOU GET THIS REPAIRED!!! Your Kirby needs carbon brushes and if you don't already need a new armature, the worn out brushes will destroy the armature that you have. Here is a guide that will help you get down to the carbon brushes to change them...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
It is a guide to replace the power switch, but will give you the step-by-step to get down to the carbon brushes.
Hope this helps,
Marci
Jun 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampooer g7d interchangeable with other g series shampooers
I believe you called me after posting this question but for all other folks that may come across I'll repeat - ANY of following Kirby model shampooers will work - G3; G4; G5; G6; Ultimate G, Ultimate G diamond edition and Sentria.
Good feedback would be appreciated
THANK YOU
Dec 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Manual and a shampooer
Wow... this is not OK price.. this is fantastic deal. I buy those in lots and I pay more per unit than that...
I am sure - nobody will beat our online manual price as it is FREE . Click HERE to see it. As far as shampoo system - if you spend enough time you may be able to find one cheaper than in our store so you choose what you want to do.
If you had a kirby that was 1990 or newer - it has not changed much. If you had one older - then you will love the power drive option on the Ultimate G and it has more power than models prior 1990
Dec 06, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G5 - Stopped
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
Nov 07, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
