Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Power supply I bought this Hard drinve used.they did not include the power supply any Idea what might work for me Thank You
  • stressed350 Oct 11, 2008
    Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Problem Solver:
I removed the sata drive then installed it into a new case for $30.
Posted on Oct 12, 2008
Dear Guru my power supply of my computer with model enp-2120d doesnt work no power output so please gave me some idea or schematic diagram,thank you.
Do not try to fix this power supply. Better to replace with new or good used. I see many on ebay from 13.50 to 25.00. Also google that model for other options. Most likely fuse on the power supply has failed but if you bypass the fuse, with jumper wire or another fuse, will blow again. Probably capacitors. Good luck
Aug 28, 2011 | Enhance Technology ENP-2120D (ENP2120D)...
Hello, i bought a ledrain 36 about 3 yrs ago the fuse just keeps blowing every time i replace it could you please give me some idea what the problem could be because non of the pcb looks burnt...
The power supply has likely failed. Schematics are hard to find and working on these takes some skill. The supply is a switching type and usually the main switching transistor and sometimes the driver and the regulator chip fail. There OFTEN is NO visiblke evidence of the failure. To avoid blowing fuses use a 40 watt lamp in series with the power cord. For personal safety use an isolation transformner when troubleshooting.
Aug 03, 2011 | Chauvet LEDrain 36 CHVLEDR36
When i plug it it worked but now it doesn't so i change of computer and it work again but when i unplug and decide to use it again it didn't work again
You likely need to power the hard drive from and external power supply or use the included "Y" cable to plug into 2 USB ports at the same time. Some USB ports on computers do not supply enough power to operate correctly. If the hard drive did not come with a power supply or the "Y" cable, contact SimpleTech and purchase this accessory.
Apr 17, 2011 | SimpleTech FS-U25/500E 500 GB USB 2.0 Hard...
Hi guys, i have a power supply HP-Compaq-226519-001 bought from ebay. the seller said it is a working pull-out and i was able to locate the AC input terminals/pins as well as the DC output terminals but...
Go to this link. Click HERE. Unplug from the motherboard FIRST. (all other leads too) You can test by using a paper clip to short pin 14 (green) to 13,15,16, or 17. This will power on a working power supply.
Apr 08, 2011 | HP (226519-001) (226519001) 3000-Watt...
No power how do I check or diagnose the power supply? Thank You
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hope this helps also
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 05, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Power supply
No.
If a power supply ends up in smoke, this usually is just bad luck (may of course be related to a bad design of the power supply or use of low quality components).
As for the BIOS settings: If you were messing around with certain overclocking settings (or are not sure if someone else did), it may be a good idea to use the "Reset to defaults" option. However, wrong BIOS settings rather may have an effect on the lifetime of motherboard and CPU but not on the power supply.
Just make sure that you use a power supply of sufficient wattage: 300W or 350W for a standard PC, somewhat more if you have a high end graphics card or many hard drives / optical drives.
Apr 03, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Power Cord
Try to search on compassmicro.com site and select inkjet then picturemate, it will give you info for part numbers, are you in us or uk? its one of their distributor.
Apr 13, 2008 | Epson PictureMate (C11C556001) InkJet...
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Won't turn on - dead dead dead
I since the problem is a stuffed battery ort else the power pack has ceased to exist. One thing is the way you have explained it seems the Laptop is ok try and find someone with a another powerpack maybe the battery ok it seems to me the pack has poked? Goodluck I wish all the problems seem simple like yours.
Sep 02, 2007 | Toshiba Satellite M45-S169 Notebook
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
73 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
