Question about Dishwashers
John Lewis JLDWW906 Slimline Dishwasher, White. Hi all, have a problem with my dishwasher. The display is showing an error of i30. Can't reset it. Have checked the filter etc and everything seems fine. John Lewis technical advice not open till Monday and engineer can't come till Thurs. Help? Thanks
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
murdozzz2
  • 75 Answers
SOURCE: Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Posted on Jan 11, 2008
SOURCE: AEG dishwasher 80850 code i30 reset
empty it, tip it on its back, mop up the spilt water, reload it and all should be ok. it is a recurring fault on our machine very irritating
Posted on Jul 30, 2008
  • 1462 Answers
SOURCE: slimline Bosch dishwasher installation
adjustment fot foot is at front middle
Posted on Oct 05, 2008
heralddriver
SOURCE: DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
Error code i30 (leak). How to fix it?
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
Dec 13, 2015 | Electrolux Dishwashers
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Oct 10, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
My dishwasher keeps flashing i30 and wont start what shall i do
In your case occurred intervention of anti-flooding system.
Displayed Error is "i30"
The cycle is interrupted and the drain pump switches on.
Could be:
Water leakage from the tub - sump and various
connections (pump, upper spray arm duct etc.);
floating sensor blocked mechanically; microswitch
faulty; fill solenoid blocked mechanically; circuit
board faulty (solenoid triac short-circuited); wiring
faulty.
First, try to tilt dishwasher and see if leaking water from its bottom.
This is most commonly occurs.
Dado
Jan 20, 2014 | Electrolux Genuine ZANUSSI ZDF511...
I have a John Lewis dishwasher and all the lights are on red
all the lights will be on before you select a cycle, if the Rinse Aid and Salt warning indicator lights are on you need to add rinse and salt to the appropriate fill up locations
Dec 30, 2013 | John Lewis JLDWW1200 Dishwasher
John lewis integrated dishwasher
make this test and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Jul 24, 2013 | John Lewis JLBIDWS1804 Builtin Dishwasher
How can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
Jul 22, 2010 | AEG 24 in. Favorit 60830 Free-standing...
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
