Question about Acer Aspire 3680 Laptop
Showing messange my laptop awlays showing window cannot find c:\window\system32\winsit.exe on desktop whenever i log in to my system. what this could be, some says its a virus but i did the scaning tooo but still it appear. your suggestion will be helpfull, please
Desktop and taskbar are being hidden by white screen
First you have to get administrator privileges (if you already do, Ignore this) but when starting up your computer get into recovery mode (Esc then F11, or whatever you have to do in the startup menu). If you have HP support on your computer, click the center panel and go into command prompt cmd prompt you cd to System32 folder on windows 7 (like C:\Windows\System32). you do that, then follow this order very carefully: copy cmd.exe cmd1.exe then rename sethc.exe sethc1.exe then rename cmd1.exe sethc.exe then get out of recovery mode, but typical people have NORMAL COMPUTERS. when you try to recover, hit cancel when asked about system restore. When the error message pops up, click on the details, open the text doc, and click save as. In that window, you browse to C:\Windows\System32 and basically do what you can do in the cmd prompt. copy cmd.exe, rename sethc.exe, then rename cmd.exe's copy to sethc.exe, then reboot normally. trigger sticky keys (hit shift many times) which brings up the command prompt. You can type explorer.exe into it to bring the taskbar up. click on the show desktop button
Dec 08, 2013 | Microsoft Windows XP Home Edition
Laptop logs off when i log on. what can i do
Edit these values and type the correct path of shell :
Shell = explorer.exe
Userinit=X:\windows\system32\userinit.exe
NOTE: These files may also be deleted by spywares. You may need to extract them using Windows CD.
Steps for rectifying this problem:
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit these two values in right pane:
Shell
Userinit
Change these two values to
Shell=explorer.exe
Userinit = x:\windows\system32\userinit.exe
Exit from Registry
Restart Infected computer.
You should be able to log on to computer.
if it not work then go to back steps and just copy orwrite the file userinit.exe
Performing the above steps will resolve the issue.
Hope this helps.
Jul 07, 2010 | Dell Latitude D400 Notebook
I would try to log onto my laptop, but right after my desktop would flash, it would immediately log off. Why?
because ur laptop have virus log on, now u go to safe mode and use software virus to scan. if u have another laptop u copy file userinit.exe from it and boot from cd after copy this file to c:\windows\system32\
Jan 16, 2010 | Sony VAIO VGN-FS742/W Notebook
Windows script host
My Documents Folder - Opens Upon Boot
To Stop Windows Explorer from opening My Documents: Check your settings here: Start/Run/Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
In the right pane under Userinit - Change the key that reads:
C:\Windows\System32\Userinit.exe,C:\Windows\System32\Userinit.exe
To:
And also here: Start/Run/Regedit
Start/Run/Regedit
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows. In the right pane, check your settings under Load.
try this rate the solution
Jul 06, 2009 | Computers & Internet
How do i fix boot on my laptop
Seems that adware ,spyware or a virus caused this.
I found a solution that could work from this forum :
http://www.geekstogo.com/forum/Windows-XP-Logs-Then-Immediately-Logs-Off-t15771.html
It's an advanced technique and you will need your Windows XP setup CD.
Boot using your winxp cd.
Enter recovery console.(press R on first screen)
at the command prompt go to
C:/windows/system32
next type:
Dir *.exe
If you find, it, type
copy userinit.exe wsaupdater.exe
Exit and reboot normally. You should now be able to logon.
Run regedit
Navigate to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\
In the right pane, you should see
C:\WINDOWS\System32\wsaupdater.exe,
Change it so that it reads:
C:\WINDOWS\System32\userinit.exe
That should solve the problem
May 11, 2009 | Computers & Internet
Hijack taskmanag and hijack regedit removing
to repair it you need to install autorun eater.
download here: http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
install and it will scan.
also suggested to install avira, bitdefender or mcafee(trial also work).
after install.
restart: press f8 you will enter safe mood. in the safe mood you will see a icon on your taskbar name by mcdonald(the autorun eater software. right click and selct repair task manager, right click again selecr repair regedit and do the same thing select repair folder option.
after that wait untill about 30 minutes(autorun eater to finish scan)
to repair other like no desktop icon download the repair utilities here:
http://www.kellys-korner-xp.com/taskbarplus!.htm
Jan 27, 2009 | Dell Latitude D600 Notebook
Desktop Error Message
Probably this is a spyware, use a good anti spyware or do the following:
Run Process Explorer (right click on task bar>task manager>Processes) and Kill the Following Processes:
wscript.exe
dxdlg.exe (kill this one first)
Run Autoruns and under logon tab, remove
C:\WINDOWS\system32\wscript.exe C:\WINDOWS\system32\boot.vbs
Search for entries named wproxp and remove it
Remove the following files from your PC:
C:\WINDOWS\system32\dxdlg.exe
wproxp.exe (Most probably in your system32 or windows folder)
Jul 06, 2008 | Computers & Internet
Virus in system
is not every viruses that and anti virus program can handle. there r some viruses that requires manual removal so ys may be a case.now u try to vies the folder where it says it found a virus then folow a path to that folder u should see the file infected then delete it.iyt should go off.
thank u
May 29, 2008 | Computers & Internet
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Acer Aspire 3680 Laptop Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
