Advent 7103 no power supply when turned on pluged in to mains supply checked fuse ok in plug
  • jamie_alton Jan 20, 2009
    hi my prob is the same
    Sergeant:
    Champion:
  • 331 Answers
I guess our smps may hae blown....
u may need to replace it...............
Posted on Oct 11, 2008
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Hello I've have got a Panasonic TH-50px80u No power I remove the rear pannel and used a volt-Ohm meter to meter the two t8ah fuses they were both open i replace, they aga
Replacing and configuring a main power board to a Plasma display is not a simple job as you thinks. With only a multimeter, you can't do anything. It is a skilled work. Contact any experienced service technician. If you wish to get more details about the repair process of plasma displays, check this link. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 29, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Advent 4211-C won't power up on AC or battery. The only sign of life is the battery charging light which displays green continuously when the computer is plugged in to the mains... apart from...
You may have already tried this... Please remove the battery to see if the machine responds to pluged in power by itself. Press the power button for about 30 seconds befor pluging in the power... this is usually the way to reset the laptop. A defective battery can keep the machine from working.
If there is no response, the motherboard may have been damaged or a solder gotten loose, either way, it would need to be taken apart to verify and the solution could be expensive.
Aug 25, 2011 | Advent 4211c Notebook
OK i went to go turn on the wii the light wont come on and it will not come on at all. What should i do and what should i check???
You need to check that the power supply is working. To this safely you will need a voltage meter. You can buy multimeters from most electrical or electronics stores such as maplin. On the power supply there is a diagram showing the power pins and the voltage output. You should be able to read 12VDC across the pins when the mains power is connected. If there is no 12VDC then check the fuse in the plug. This is a 3A fuse and it can be easily removed from the plug with a suitable flat blade screwdriver. Use your multimeter on resistance (Ohms) setting or on continuity (bleeper) setting and test across the two ends of the fuse. If the resistance is nearly zero or the multimeter bleeps then the fuse is OK. If the fuse is Ok and you mains socket has power but there is no power output then the power supply is faulty. If there is 12VDC out of the power supply then the Wii is faulty. If it is under warranty then take it back to the store. If it is out of warranty then get someone to fix it (if possible).
Feb 20, 2011 | Video Game Consoles & Games
On pluging on the main AC pluf, there is not
do you have the cord plugged into the computer? is there a switch on the back near the power supply? if so, is it on? is the large connector from the power supply tightly latched to the mother board? (unplug the computer before you check this!) any fans running? plug a lamp into the outlet and see if it has power! could be a popped breaker, or blown fuse.if you feel confident of your skill, remove the power supply, open it up and see if it has a fuse that may be blown. if so, replace it with a fuse of the same type (size & amperage). if the fuse was blown, and you re-install the power supply and it blows again, then you have a problem (probably) with the power supply, and if cost effective, it needs replacing! get a compatible power supply with a higher power rating, if you can! more power for your peripherals!
good luck!
Sep 28, 2009 | Compaq Evo D510 Minitower (Open Box)...
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
I am having exactly the same problem
Its not recognising the power supply.Get the power supply checked in the laptop.
Jul 06, 2009 | Advent 4211c Notebook
Advent ht3251a wont turn on
working on same model same symtons,pluged sys into a vareact tv came on normal,problem gone.set works ok when plug into ac outlet.can,t say what cause problem,set work ok now without veriact.will air test three days to see if probem returns.will try freez spay on chips.
Feb 20, 2009 | Recoton Advent Advent HT3251A TV
Laptop does not take any mains power
Try clearing your CMOS. This is done by removing battery and mains power, lifting the speaker cover off and then look under the keyboard. Unscrew panel where keyboard ribbon enters, you should now see your RAM & BIOS chip. Disconnect ribbon next to BIOS chip and reconnect, that should clear your CMOS.
Dec 01, 2008 | Computers & Internet
My tv turns on and then shuts off after 10 seconds . i recently had power surge and the tv was plugged but off . what could be wrong?
sir?? i think the power supply of ur tv is defective???kindly check it out the power supply section,,,thnkzz and hope too help you!!
Jan 29, 2008 | Recoton Advent Advent AW-871 Main / Stereo...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
