Question about Mitsubishi HS-U447 VHS VCR
Tape will not play rewind or foward
It happened gradually, now when I press play, rewind or foward, it tries then stops. I thought at first it was the old tapes, but now, it won't play at all? Any suggestions before I have to take to repair shop?
  • MMu1411 Feb 18, 2009
    Tape will not play rewind or foward; the machine tries, there's a slipping / rubbing sound, then the machine stops trying
  • 905 Answers
In the vcr there are clutch disk pads in the gearing that wears down and or the belt is slipping or broke , it will need repair
Posted on Oct 11, 2008
  • jason Oct 11, 2008
    thank you for your rating! I fix electronic devices and the cost for this kind of repair costs aprox $40 It should include cleaning , lubrication and any adjustments needed.
    again thank you!
How do I stop my vcr (GE mod vg4258) rewinding when I want to stop it b4 the beginning of the tape?
Press "play" and then "stop". This will not hurt the player unless its tape transport systems are broken.
Oct 06, 2014 | Televison & Video
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have a multitrack cassette recorder MCR-4 made by AMR. In fast foward or rewind it only runs for a few secounds and stops. It does this each time you press the direction button. The tape does stay...
Hi the most common problem i have found here is that although the tapes look OK, they are very tight in case to go forward/back. Banging on the side of the cassette fairly hard on a flat surface a few times, both sides, quite often get rids of it. If that doesnt work, then will need a service on machine. Also try a new cassette..
Best of luck
Jul 24, 2009 | Audio Players & Recorders
Video tapes only paly for about 2 seconds then stops
The heads need cleaning and/or the tapes are old and dirtying up the playing heads.
Run a wet tape head cleaner through an see if this improves.
May 23, 2009 | Televison & Video
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
Cassettes not rewinding
The heads could also just need a good cleaning, either professionally or using a head cleaner dv tape. It's important to remember to always use the same manufacturer dv tape all the time. Evidently, Sony and Panasonic do not mix well, and the lubricants from those two tapes combined will gum up the works. If you use Sony dv's, always use a Sony head cleaner and vice versa. Cold can also cause those lubricants to gum up. Sometimes simply fast forwarding will loosen things up.
Nov 25, 2007 | Video Cameras
Player - rewind malfunction
I have a trv-58 with the same problem. One way is to press play and rewind while in play mode.Getting back to the first of the tape is a chore.
Sep 24, 2007 | Sony Handycam CCD-TR416 Camcorder
Will not play back
Usually if there is no impact injury involved or nagging intermittent past problems, you probably have a head cleaning issue. Try a dry type (reccomended) cleaning tape. Should be able to purchase at Best Buy or similar store. Good luck, magic seadog
Jun 10, 2007 | JVC Cybercam GR-DVL805 Mini DV Digital...
Mitsubishi HS-U447 VHS VCR Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
