Question about Sony Ericsson W200i Cellular Phone
Calls when opening the menu and select calls>all.there are 30 contacts see but last 24 to 30(6) contacts cannot be seen and it remains blank
    Brigadier General:
  • 7,752 Answers
Try resetting the phone
Posted on Dec 28, 2008
We have just purchased a Uniden Xdect 8355 series telephone. When the phone rings we get a message telling us who the call is from, how do we get rid of it?
Do you want to delete entries from the Caller ID list? This records the numbers of the last 50 incoming calls. You can't delete the entire list at once. However, you can delete one entry at a time. Press CID on one handset or base with the entire system in standby (no active calls). The CID button is to the right of the Menu/Select button. Press the Up/Down arrows (above and below Menu/Select) to select one call. Press Menu/Select to get the details of that call. If you don't see list with Delete Entry, Add to PB, and Add Call Block, press Menu/Select again. Select the Delete Entry line and press Menu/Select. Select Yes and then Menu/Select again if prompted to confirm the deletion.
When you are done, press End/Clear to exit the menu system. You'll find these directions on page 30 (page 31 of the pdf) of the manual. Uniden has the manual here: .
I hope this helps.
May 18, 2017 | Uniden Lands Phones
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
How to retrieve sent voicemail from yahoo messenger?
1. Select Voice Messages & Call History from the Contacts menu in the Messenger window.
2. Right-click a contact in the Messenger List and select Voice Messages & Call History from the menu.
3. The Voice Messages & Call History window opens. Unless you've opened the window with a specific contact selected, the window displays your voice messages (if you have any) or your entire call history
Jul 05, 2011 | Yahoo Messenger
I have a Roll Up II digitiser with Quik Ruler when starting up, after self run test has passed it says: Press switch to relocate Menu, and it gives just a few seconds to do so, If i dont select anything it...
You may have an open line in the grid of your Roll-Up and the Quikruler can't find a good point.
Turn on your RUD II and Quikruler and let it go through the sequence and place the cursor on the RUD.
There should be numbers displayed on the QR, if you take the cursor and go from the left part of the RUD to the right and see any of the numbers disappear, than you have on open in the RUD.
Call GTCO Tech Support and ask for an RMA if you want it repaired.
Aug 13, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Error 0x80040fb3
Typically its caused by a contact not having a FIRST NAME, LAST NAME and COMPANY NAME. (don't confuse FIRST NAME and LAST NAME with FULL NAME, they're not the same!!)
Do an advanced search in Microsoft Outlook to find contacts with blank First Name, Last Name, and Company fields.
1. Open Contacts in Microsoft Outlook.
2. Open the Tools menu.
3. Select Advanced Find from the Find submenu.
4. Select the Advanced tab.
5. Click Field.
6. Select First Name from the Frequently-used fields submenu.
7. Select is empty from the Condition list.
8. Repeat steps 5 through 7 for Last Name and Company.
9. Click Find Now.
Any contacts you find as a result of this need to be modified to include a first, last or company name (not all 3, just one of the 3)
By upgrading to DTM 4.2.2 or higher, that problem should be ignored (skipped), so if its still happening, I'd first go through the steps listed in that link above.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | AT&T Blackberry Curve 8300 Smartphone
Security code for Nec lt260 multimedia projector
The menu and logo password are the only ones you can reset by yourself, if you lose your master password you must contact NEC to get the release code.
See page 113 on the manual :
NOTE: Do not forget your keyword. However, if you forget your keyword, NEC or your dealer will provide you with your Release Code.
After you call NEC and get the code do the following:
1. Press and hold the POWER button for a minimum of two seconds.
The projector will be turned on and display a message to the effect that
the projector is security-protected.
2. Select [Projector Options] → [Security] from the menu and press hte ENTER
The Release Code input screen will be displayed as well as your Request
Code (24 alphanumeric characters).
3. Enter your Release Code in the Release Code Input screen.
The projector will turn on.
* If the projector is turned on by entering the Release Code, your Security
will be disabled.
find contact page from here or call the retailer:
NEC Global
Here is also the remote
Sep 10, 2008 | NEC LT20 Multimedia Projector
Hiya, I've got a samsung u900 and when the phone has been idle (slider down and keys locked) even for just a minute when some one rings me the keys light up but the screen remains blank no light or...
Adjusting the duration of the backlight
To adjust the duration, perform the following steps:
1. At the main screen, select Menu.
2. Scroll to and select Settings.
3. Scroll to and select Display settings.
4. Scroll to and select Light settings.
5. Scroll to and select Backlight time.
6. At On, press the OK key.
7. Scroll to one of the following options, and then select OK:
  • 10 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
  • 10 minutes
8. Scroll to Dim and press the OK key.
9. Scroll to one of the following options, and then select OK:
  • Off
  • 5 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
10. Select Save.
Aug 07, 2008 | Samsung Cell Phones
Desktop is blank
Shut your off. Wait 30 seconds. Boot the computer up into safe mode by pressing f8 before the Windows screen appears. Select Safe Mode and press enter. Once the desktop appears, restart your computer the normal way.
If it continues you should reinstall your operating system to fix the problem.
Aug 02, 2008 | Microsoft Windows 98 for PC
Not printing (paper comes out blank)
it is possible that is has problem on your printer's memory... try printing below 30 pages see if problems still persist.
Mar 07, 2008 | Samsung CLP 300 Laser Printer
Sony Ericsson W200i Cellular Phone Logo
19 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
