Question about Tascam Audio Players & Recorders
My DA78HR has been working fine but on switching the deck on this morning I began to rewind the tape from yesterdays recording session only to see the rewind stop and the display read 5-Err.00 which alternates with 'no tape' I cant eject the tape as the deck isn't recognising that there is one loaded. I'm stuck. I have removed the casing to see if I could identify any obvious physical problems without success. Can you offer any advice? Regards Phil Udall
  • 4 more comments
  • amoebachem Oct 11, 2008
    I cannot try another tape - because as I stated
    before ...the DA78HR will not eject the existing tape.
    The machine is not recognizing that there is one loaded as the display is reading -
    5-Err.00 No tape.
    Have unplugged the DA78HR for 10 minutes and re-connected to try and restore the logic by default but no difference I'm afraid.
    The reading on the display is unaltered at
    5-Err.00 no tape
    The DA78HR will not accept any instructions at all so it will not play, wind, rewind or eject.
    Hence I'm stuck.
    I dont think the tape is damaged as it is new.
    It is not possible to remove the tape from recorder as it is still engaged around the 8 track head mechanism which is very delicate and attempts to remove it will prove very unwise and could cause permanent damage.
    The problem is more likely to be in the logic circuits somewhere and I fear will require diagnostic check with a TASCAM service agent.
    No - I can see the tape engaged around the 8 track head and its guide posts. It is not entangled at all but it is not possible to access the tape as it not like a conventional cassette recorder.
    Even if this was possible the logic circuit is not recognising that there is a tape in the machine so the eject button will not release the tape from its position.
    Hi -- Are you able to offer any further advise to your earlier suggestions?
    Scholar:
  • 142 Answers
Hello!
NICE unit!! I have worked on quite a few Tascams. The tape needs to be removed by hand by applying dc to the motor that loads the guides (unit unplugged\red lead to the motor unplugged so the motor drive IC doesn't burn). After that has been achieved the "tape\no tape loaded" switch needs to be checked and replaced if necessary. I believe this is the problem...malfunctioning switch. If you can't perform these steps then the unit needs to go to an authorized Tascam service center. Good Luck!
barneyluc
Posted on Oct 11, 2008
  • Barney Lucas Oct 12, 2008
    Just for fun here because I don't believe you are going to ever to click to PAY anybody...IrishDruid dude it doesn't sound to me like you should be responding to any electronic repair problems. A "hard reset" is when the unit is on and you take a jumper wire... clip one end to ground and then touch the other end to the reset pin on the microprocessor. Microprocessors are reset by the reset circuit every time you turn on.
    Genius:
  • 1,550 Answers
I think the tape is damaged .
Remove the panel to get the tape out
  • SAM ANDERSON Oct 11, 2008
    When you open the panel you can see the tape is strewn around inside or wrapped around a capstan.
    Dont force to take the tape out .
  • Tascam Master
  • 19,396 Answers
Let the tape finish to rewind, when it is finished unplug power cord for ten minutes.
Plug back and see if you can eject the tape.
If tape does not eject , you will need to take apart the unit.
    President:
  • 2,712 Answers
Try a hard reset first - unplug from power and wait 5 minutes before replugging. Let me know how it goes..
  • Swilin Sampson
    Swilin Sampson Oct 11, 2008
    Are you able to rewind the tape at all? If not, it would indicate that the tape may be entangled among the rollers. In this case, you will have to remove the panel and remove the entangled tape. That should resolve the issue.
    Sergeant:
  • 264 Answers
Have to tried another tape
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
How to record live sounds
Plug a monitoring headphone into the monitor socket and try to record if the sounds that you try to record with is working. With an oscilloscope check the recording head is there a sine wave signal if not then the oscillator is kaput record switch operating correctly?what is the age of the tape itself? Was it played back a lot of times? I found this when some tapes refuse to take other recordings when used a lot
It is difficult to say what went wrong if you do not have access to the unit
May 28, 2013 | Technics RS-TR575 Single Dual Cassette...
During transcription, when you release the foot pedal, the tape automatically rewinds a little so you can resume easily. This no longer happens with my machine. I have tried several foot pedals, but the...
It could be the rewind solenoid is jamed up or there is a switch that comes loose under the tape deck. Either way, it will need to be serviced.
dictationmall
Nov 01, 2011 | Panasonic RR-830 Desktop Cassette...
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
Lanier Advocate V System - Automatic Changeover
Hello make sure you full rewind the erase tape on the deck 2 you will see the green light Ready, that’s when you can start the Deck 1to record when is almost to the end Deck 2 will start
Jan 22, 2010 | Audio Players & Recorders
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I...
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
Oct 11, 2008 | Pioneer Audio Players & Recorders
Error F03
I suspect that only one capstan works, The belt driving it might be broken or something else on the drive.
Apr 28, 2008 | Audio Players & Recorders
No playback
The record-play switch may not be fully changing back to the Play position. Look for a bind in the mechanism that moves the switch.
Oct 11, 2007 | Audio Players & Recorders
193 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
