Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 'error' and 'clock' message
My D80 is not working. It turns on, but none of the functions are working. There is a flashing 'error' message and 'clock' message on the display screen.
I am using it in quite humid conditions, but the camera was working fine until today, and now it cannot take a picture. Please help me.
Thank you,
Nick
  • 8 more comments
  • jmdo1 Oct 17, 2008
    Humidity affected my camera. At first it would not take pics at all, showing an r06 on the display. Now I can take pictures but I cannot get into the Menu screen nor modify ISO selection with manual commands. Very weird.
    Every time I try to access an affected command I got the r06 thing. Thanks.-
  • michelleskoy Nov 08, 2008
    I have an error FEE in the upper right corner of the display. Nothing else functions...
  • steve29262 Nov 11, 2008
    Hello, today my camera stopped working too. The display lights up and shows ERR and the clock message flashing. Nothing else works. I've tried taking the battery out and left it for ages, but still it's not working. Any ideas??
  • jpthekid Nov 18, 2008
    flashing error message. all functions stop. a couple of times i was able to solve it by removing and replacing the lens. now that doesn't work anymore.
  • nnewcomb Nov 29, 2008
    My d80 picture button will not depress in any mode but manual then I only get a black display any solutions?
  • Anonymous Jan 02, 2009
    me too
  • Anonymous Jan 10, 2009
    same it, it just happened yesterday!
  • Nanakshahi Feb 16, 2009
    I am unable to take pictures from my D80. There is a error message [CHA] flashing on control panel. Please help!
  • amarindersid Mar 15, 2009
    my d80 have same problem error and clock flashing after few shots
  • Anonymous Apr 12, 2009
    exacly the same problem
    ''clock'' error message
La batería del reloj
El reloj de la cámara funciona con una fuente de alimentación independiente y recargable que se carga si lo necesita
cuando la batería principal está instalada o la cámara se alimenta mediante un Adaptador opcional de CA EH-
5. Dos días de recarga proporcionarán al reloj la energía suficiente para aproximadamente un mes. Si parpadea
en el panel de control, la batería del reloj está agotada y el reloj ha vuelto a la hora de inicio,
2006.01.01.00:00:00. Ajuste el reloj con la fecha y la hora correctas.
Posted on Nov 26, 2009
My d80 shutter is malfunctioning. After a good shot a flashing ' error' message is display on the control panel. The image is alternately capture.My d80 is almost a year now.
Please help me
thank you,
Riche
Posted on Nov 11, 2008
My D80 is suddenly dead. I was uploading photos to my computer yesterday. After most of them were uploaded, an error message popped up saying an error kept it from uploading the next one. It kept popping...
This is why the pros always use a card reader instead of the camera. When you disconnected the camera, did you remember to use the "safely remove hardware" function? The computer was obviously still trying to write and communicate with the camera and if you just disconnected it, the camera became corrupted. Check your manual for instructions for a camera reset. Try that. Also, remove the card and batteries, press every button, leave it alone for 20 minutes, insert the card and then the batteries, turn it on. Sometimes this works.
Oct 10, 2010 | Nikon D80 Digital Camera
How to fix the error problem in nikon d80 camera?blinking error message at the left side on the top line on display screen,ill try all ways to fix but it dsnt work,ill open the camera and align inside the...
Hi ktithender, on the left side top of the LCD on the top of the camera is the battery display and the Auto ISO display. What is it you are seeing as an error message? Also, if you are opening, taking apart the D80 there is not much any of us can do to assist you. My suggestion is to call Nikon 800-645-6689
Aug 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error message at display screen
Set both the exposure dial and the focusmode to "M" and press the shutter button. Then turn the camera off for 10 - 15 seconds. If this doesn't solve the problem, it's an electronic or mechanical error.
Jul 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
When I put on the D80 Nikon camer with 18-55 lens showing err 10 or 11 in small display in place of frame counter. Otherwise auto focas work, even camera klik but picture not expose then what is the...
Hi nrkelkar, In the D80 manual page 36 it speaks about the buffer. What you see as an error message is r with a number. The number is how many shots the buffer at that moment can handle. It is not an error message.
Jul 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
Magic chef model# cer3725acw. Using stove top burner.(CAL) Error message came on briefly on touch pad display window. Can't change time on clock,turn on oven,set temp.or timer.Burners work fine. Unplugged...
It sounds like a bad control. Before replacing the control, make sure it is not in Sabbath Mode, Child lock and if all else fails try resetting the control to factory defaults. If none of these work then replace the clock/control part number 5701M827-60. This part runs about $175.00
I attached a cut out of the service manual, to show how to reset the locks and factory defaults
May 27, 2010 | Magic Chef Kitchen Ranges
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
Nikon D80 Err
You did not mention what error mesage you got. If it is a flashing "F--" then it has something to do with your lens.
This usually happens to lenses that have an aperture ring. Do the following:
1. Turn off your camera.
2. Move the aperture ring clockwise and lock it
3. Turn on the camera and see if this works
If this does not work, unlock the aperture ring and move it counter-clockwise then lock it again.
This should fix your problem
Jan 01, 2010 | Nikon D80 Digital Camera with 18-135mm...
Function buttons all pop flash
Sorry sounds like this is a hardware problem and you need to have your unit serviced.
Apr 09, 2009 | Nikon D80 Digital Camera with 18-200mm...
D80 and SB-600 FV Lock doesn't work anymore
In whacky situations like this it is always best to re-set your camera and flash settings. Somewhere on your D80 you will find two function buttons with small green dots next to them. These are the resets. Push both in at the same time until the display LCD flashes.. The camera is now reset to default settings.You will now have to re-set your FV button to the custom setting you had it at before.
Also, reset you flash by turning on the power and removing the batteries and re-install them.
Apr 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon D80 Digital Camera with 18-135mm Lens Logo
7,415 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
