Question about NetGear WGT624 Wireless Router
Wirless router c`not setup wirless connection router using 192.186.1.1 where no positive reply
  • Anonymous Mar 29, 2014
    wirless is not connected in this router
Need to open a port for ps3 don't know how to do this
Posted on Oct 14, 2008
  • 4 Answers
Try This link:
http://www.retrevo.com/support/Netgear-WGT624-Wireless-Routers-manual/id/420dj078/t/2/
Posted on Oct 11, 2008
Dhcp is not enabled for wirless network connection
you will need to open the setup page of the router. Do u have any computer connected to the router?
If not then do you have any computer online using the wireless connection ?
on that computer, you can open the setup page of the router.
On this page you will get all the settings of the router.
Click Here
for step by step by instructions
Jul 12, 2010 | NetGear WGR614 Wireless Router
Tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 | Computers & Internet
I cant go into the router i think i changed something on the router setup and now it cant go back in.i can connect to the internet directly from the cable modem but when i plug it in the wirless router it...
Try using the hardware reset button on the Linksys. Every settings / changes you have done will reset.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jul 07, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
NETGEAR wirless router installation
You can use below steps to install router
ROUTER SETUP
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.1.1 address bar. press enter
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on lan ip setup under advanced.
6. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
7. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
8. Power off the dsl modem and the router after making the connections.
9. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
10. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
11. Access the router (http://192.168.10.1).
12. Login to the router (Username = admin Password = Password).
13. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
14. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
15. Click Apply.
16. Logout of the router.
17. Open up another browser window and try to access internet.
Please rate the service positively if issue resolved
Thanks for using Fixya
Apr 04, 2010 | NetGear RangeMax WPN824 Wireless Router...
How do you hook up a dynex 802.11g wireless router
To setup your Dynex router you can follow the below steps
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.0.1 and then type the username as "admin" and the password is blank so leave the password box as blank
  5. You need to set it up as per your internet service provider if you do not have any fixed IP address provided by ISP then select dynamic IP address and then click on clone mac address after saving these settings on the router setup page you can check if you are able to access internet then you can do the wireless settings
  6. Once the router setup page is open you can confugure the router easily without the CD setup.
  7. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  8. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  9. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  10. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  11. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
Dec 03, 2009 | Computers & Internet
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
How to secure my wirless connection
You could set up a mac address filter with just your routers address or you could set up a wireless key that only your computer uses. Here is a quick tutorial:
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx#3
Jun 18, 2009 | Belkin (F5D9230-4) Wireless Router...
I had my DSL disconnected. I am using cable internet w/Comcast. I've DIR-628 connected to Mot-SB5101 Cable Modem. This setup is working fine. However I'd like to use my old DSL/Router 2wire 2701 to connect...
First you should see a wirless icon on the botom left of your screen wich is on the task bar. The say view wirless networks or what ever it would say then you should see a list of avalible networks at that time. The slect the network that you own an say conect. When conecting it way ask for a WEP password which is located on the router. I hope this will help you.
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
I want fast help..how to get connection between linksys router and aztech modem
first check..
Step 1:
Step 2:
Step 3:
Step 4:
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
111 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
