Question about Samsung NV10 Digital Camera
Software probs i have a samsung nv10,love the camera,but i have now got a new laptop that is windows vista my software disc for the camera will not load,help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Posted on Feb 23, 2013
Gwenivie
  • 39 Answers
SOURCE: SAMSUNG NV10 camera: need driver update for MS Vista.
If you're Operating System is not listed on the CD that
came in the package. You could freely download the software
that is compatible with all Windows OS like Vista.
Just visit this website:
https://www.samsungcamera.com/customer/download/cus_utility_view.asp?suc_seq=14&dcd_fg=UT02&page=1&keyfield=&key=
You could just copy and paste that link to your web browser.
Or try the steps below for you to proceed there
- Go to www.samsungcamera.com
- Mouse over on Support
- Click on Download Centre
- On the leftmost part of the page,
click on UTILITY
- Select on SOFTWARE tab
- Click on Digimax Master V 1.1
* If it still does not help, call the Manufacturer.
Posted on Jan 19, 2008
  • 3 Answers
SOURCE: Cannot load concord camera Eye-Q Duo 2000 Software
i jus plugged mine into usb port and it downloaded the drivers for me without using mah disc at all...
Posted on May 23, 2008
SOURCE: Samsung NV10 heeelp!Pleeease
I HAVE THE SOLUTION
I had the exact same problem and now it works perfectly.
The lens assembly needs a little WD-40. Warning, DO NOT spray on the lens assembly itself. You do not want to get WD-40 on the glass part of the lens itelf. Here is how you do it:
1. Turn on the camera and let the mechanism project the lens out as best as possible. You may help it out with your finger-nail at front slowly pulling at the lens. Do not use force. If you can only get it half out, then that should be fine too. It will probably beep at you and turn off again. That's okay.
2. Take a sheet of paper and spray some WD-40 on the edge of the paper.
3. Gently apply the sprayed part of the paper around the lens between each of the lens cylinders (where it telescopes out.) You want to trickle tiny bits of WD-40 into the mechanism.
4. Turn on the camera and do step 1. again. It may now already work a little better now.
5. Do step 2, 3 and 4 again and maybe one more time until you have lubed up the mechanism well enough to the moving parts nice and slippery.
6. Use your good judgement. Turn on and off the camera until you notice that your camera lens mechanism no longer gets stuck.
I did this about a month ago with my NV10 and it still works like new.
Good Luck!
muga
Posted on Aug 01, 2008
  • 26 Answers
SOURCE: samsung nv10
please try to download the driver here
install it and try to connect again you camera
hope it helps ^^
Posted on Jan 09, 2009
  • 296 Answers
SOURCE: can't find vista drivers for samsung nv10
You can find the driver from below link:-
http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=NV10
Thanks!
mannu_rakesh
Posted on Aug 14, 2009
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Aug 10, 2010 | Samsung NV10 Digital Camera
Need manual for Samsung digital camera VLUU NV10
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=04010900&prd_mdl_cd=&prd_mdl_name=NV10
Nov 15, 2009 | Samsung NV10 Digital Camera
Problem with camera
The lens is sticking, I had same problem, thought it was the battery. It kept doing 4 beeps and turning off, but the lens would be out.
Lightly lube the lens area with WD 40 worked, be real careful and don't use alot of it. My camera works fine now. I actually read the solution someone on this site, can't find it now, but wanted to post that it worked for me. I love the camera and was bummed it wasn't working. Works great now!
Aug 04, 2008 | Samsung NV10 Digital Camera
Inability to load r967 software disc with windows vista
Hp has digital software for most digital cameras to work with Vista the link should help. http://www.hp.com/united-states/consumer/digital_photography/free/software/index.html
Feb 19, 2008 | Cameras
Samsung NV10 not detected when connected to PC / computer
I had the same issue. Try checking in Control panel > Admin Tools > Disc Management. If it shows up in there, then it's recognised by the PC, and there must be a drive assignment conflict. Change the assigned drive letter to something else.
Jan 28, 2008 | Samsung NV10 Digital Camera
click on UTILITY
Dec 26, 2007 | Samsung NV10 Digital Camera
Blank Screen
There should be an option to turn the display screen on/off.
Dec 25, 2007 | Samsung NV10 Digital Camera
Windows vista unable to install my canon pixma mp500
First download and install the latest drivers for Windows Vista. Then try connecting the printer. The latest drivers can be obtained from: www.download.com/BJ-Printer-Driver-Canon-Pixma-iP1500/3000-2116_4-10555901.html
Sep 27, 2007 | Canon Pixma MP500 All-In-One InkJet...
Samsung NV10 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
