My internet seems not working correct, contacted the provider but they say everything is working correctly for them to the router. All my 3 computers have the problem so i guess it's a network problem...
  • 1 more comment
  • Luthai Oct 12, 2008
    the internet is working on all 3 computers but not like it used to be, i have nitro cable internet, my provider is SHAW. i did already tried shutting down firewalls but that didn't work. when i do a pathping with or without router connected between modem & computer, it doesn't work like it should, normally it should do a traceroute over 30 hops to the ip adress i putted in but in my case it doesn't go out. it looks like when i want to start sending it blocks because i have 100% packetloss.
    any idea's?
  • Luthai Oct 13, 2008
    I've turned down all firewalls included the one on the router, my router & modem are seperated and even when i try straight from modem to computer i still have the problem so router isn't the problem (i think)
  • velut_umbra May 11, 2010
    Do the computers "see" each other?
    Scholar:
  • 31 Answers
Hi there, my name is Alex and im here to help with your problem
It sounds to me like a network problem to. Do any of your PC's have a firewall? If they have please disable them as a firewall blocks incoming and outcoming traffic.
You say that the internet is not working on all 3 machines? Please check all cables are connected properly both ends. Do you have an IP address given to you by your internet provider? If you can give me more info about the type of connection you have, I will be able to assist you more but firstly I would disable windows firewall and any other ones you may have installed on all 3 machines
Please let me know how you get on.
Posted on Oct 11, 2008
  • Alex Woods
    Alex Woods Oct 12, 2008
    Do you use any antiviruses with a built in firewall? If so then this plus windows's firewall if enabled needs to be disabled
    Do you know how to access inside the router? You can get more info by calling your ISP and they will guide you to entering your router. When you are inside the router, check to make sure the routers firewall (if it has one) is disabled. It sounds to me like this is your problem.
    Another thing could be the settings of the router is not set correctly. You will need your ISP details in order to see if the correct information is set with the router.
    I hope this information helps. Please keep me informed.
Need to connect reurbished dell GX520 to existing internet
first connect the "cat 5" cable to the dell's network card, the card has a square-ish hole with a little "cutout" in the top (for the cable's connector tab) the other end of the "cat 5" cable goes into the back of the router (you do have an existing router?) into one of the un-used square-ish holes (same cutout for the tab).
Then turn on the computer, see if the computer will "connect" to the router (that means it sees the router in computer-ish software).
IF that works then connect the router to the Modem (supplied by the "Internet Provider"... Then turn on the modem....
IF all goes well, your computer will now be able to connect to the existing internet.
Now for problems...
IF it seems to be connected correctly using the proper cat 5 cable, and it still will not work... turn off everything, start with the internet modem, then the router, then the computer... COUNT to 30 (1, 2, 3, 4... 29, 30) turn on the internet modem... count to 90 (1,2,3,4...90) turn on the router... count to 30 (1,2,3,4...30) turn on the computer... wait for it to fully boot, look down at the lower right of the screen and see if it can connect now.
IF it still doesn't connect, you may have to try another network card in the computer, or get a wireless USB "thingy" to connect to a wireless router...
Hope this helps...
May 21, 2014 | Dell OptiPlex GX260 PC Desktop
How to connect inenter by using lan and ftp
To connect to the Internet you need a few extra things aswell as a network card and install the LAN card driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Jun 11, 2011 | Computers & Internet
I cant connect to internet but i installed the necessary driver
To connect to the Internet you need a few extra things aswell as a network card.
May 18, 2011 | IBM ThinkPad X41 Tablet PC
Do not now how to switch on internet
Apr 17, 2011 | Office Equipment & Supplies
I have a D-Link DIR655 with three macs in the household. All was working fine, but now, sometimes you get on the internet immediately, sometimes you have to try two or three attempts, waiting. Once on...
The issue here is the Internet connection you are receiving from your Internet Service Provider. Please contact them and report the problem you are encountering. because from their end, they can correct what problems in their computers that have badly affected your internet speed.
Nov 17, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Hello just bought a dlink router DIR615 I HAVE INSTALLED CORRECTLY BUT WHEN I TRY TO GET ONLINE MY MODEM I COULD NOT CONNECT
If you have not unplug the power to the modem and router then turn back on the router first then the modem most reviews forget to tell people turn off everything reboot modem router and computer for the DHCP to work properly the switch on cable modems only place the modem in standby mode you must turn off the power
Oct 27, 2009 | D-Link DI 514 Wireless Router (DI-514)
I tried everything , i hooked up my new router to my modem and begin to set it up and when it came down to connect to the internet it didn't and it said to reboot my modem and i did and it did nothing and...
firstly, go and reset your router again. Then try to set it up again with your manual. Are you 100% sure that all the settings are correct? If so, enter them and everything should work ok. If not, try contacting your internet provider, if there is any special settings you need for your modem to work with your router.
Oct 15, 2009 | Linksys Wireless-G WRT54G Router
Router not working correctly with my two computers..
If you are using an USB cord, then you probably are using a modem rather than a router.
One of the differences between a modem and a router, is that with a modem you can connect to the WAN network only one machine , while a router will assign IPs to multiple machines, connecting them directly to Internet service.
All you need is a wireless router like this. To configure the router you will need to enter the parameters provided by your Internet Service Provider company.
If you have lost the parameters, when you set the router you can call your Internet Provider to be guided step by step in setting the router.
The router can be purchased directly from your Internet Provider.
Regards.
Aug 17, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Wireless router WRT54G version 2
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
let me no know in case if you have any problems ...
Nov 18, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
