Question about Philips 20PF5120/01 20 in. EDTV-Ready LCD Television
Hey Hello, i got the same problem with the LCD monitor, 20PF5121/01. I was wondering if you got the resolution right? If you did, could you add me in msn or tell me how you got it right. I had the same monitor before with my old comp. and it was ok(it had XP), but this new one with Vista...so f*cked up. =/ So i hope you got it working and can help me too. msn:battlefield_skelet@hotmail.com Thank You.
    Top Expert:
  • Philips Master
  • 74,383 Answers
Hay Hay!!
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Jun 22, 2017
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
How do I change the screen resolution on Dell E153FP?
Hello Paul, hi, to change the resolution, simply right click the desktop wall paper, properties settings then screen resolution you want. Hope this is what your are looking for. If this is not it, you may need the VGA driver CD. this CD will install the CORRECT resolution of your monitor.
Sep 29, 2010 | Dell E153FP 15" LCD Monitor
Gateway FPD 1975W LCD monitor,on light blinking, but wont turn on
I will assume you have already try this monitor with other PC? You should also set the PC VIDEO output resolution to be at native resolution of this monitor, which is 1440x900 @60Hz.
Mar 29, 2010 | Gateway FPD1975W 19" LCD Monitor
Samsung SyncMaster 713BM
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Make sure Resolution is 1440 x 900......
hello,
did your monitor support 1440X900 resolution. if yes then go to desktop properties then change the resolution to 1440X900 then play the game.
if not support then remove the game from your pc.
ramesh
Nov 29, 2008 | Envision 19" Widescreen Flat Panel LCD...
LcD say "video Out of range
Hey...
It's mean your monitor not support to this ranges... need to reduced the resolution to mfg. settings...
Nov 29, 2008 | ASUS LCD Monitor
Proview wb926wbi monitor
Try changing the resolution to 1440x900. This is the ideal resolution for this monitor.
To change the resolution:
Right click on an empty space on your Windows desktop.
Choose Properties (XP) or Personalize (Vista)
Choose the Settings tab (XP) or Display Settings (Vista).
Slide the resolution slider to 1440x900, then click apply.
If asked whether you want to keep this setting, choose yes/ok.
Note: Not all video cards support this resolution. Updating your video card's (not monitor's) driver may add it.
Jun 29, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor off centre when booting up into dos
The monitor likely auto-synced off centered on that resolution because it couldn't find the edges of the black screen.
Try to figure out what resolution the DOS screen is using and then set windows to that resolution and then proceed to center the screen using the monitor's menu.
You can now switch back to the resolution of your liking.
On next reboot, the monitor should keep the settings for that resolution.
Feb 22, 2008 | Acer AL1714 17" LCD Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
LCD problems... Can you help me?
it has nothing to do with your computer, if you put the monitor on a different computer it will do the same thing. the message comes directly from the monitor itself. you have to keep your screen resolution at 1280 x 1024
Mar 23, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Philips 20PF5120/01 20 in. EDTV-Ready LCD Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
