Question about HP Computers & Internet
I havew a NX 9500, video chip is overheating. Found the issue, a couple of 0805 caps bad. Problem is I do not know their value...please help
    Sergeant:
    Champion:
  • 331 Answers
Their value
as in what sence???
Posted on Oct 11, 2008
HP LC3272N No video or audio??
If you found any bad caps I would suspect that board--look closely again at the caps--even if puffed a little----
Nov 05, 2012 | HP Lc3272n 32 in. LCD Television
Nx 9500 speakers are not working
this document should prove most helpful on windows XP (its native OS)
if that does not help could you please post your problem OS (if you don't know follow below)
  1. click start
  2. right-click computer or My computer
  3. click properties
  4. the OS will be in there somewhere
  • in windows 7 its near the top in the windows edition category
  • I will also need to know the service pack
here's mine
Apr 30, 2012 | HP Compaq nx9500 Notebook
Please help me to solved this issue "No Power" i found burn resistor to the power board any one know the value of resistor R504.
Please repost with make and model. Is it ACER or FUJITSU? Hard to help without details for us to do the research.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 18, 2011 | Acer 15 LCD PANEL FUJITSU Monitor
I havew a gateway FPD1975W monitor and I can not get it to fit the screen correctly. It stretches outside of the screen.
You need to set your PC video resolution to the native resolution of this monitor: 1440 × 900 @60Hz.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 15, 2011 | Gateway FPD1975W 19" LCD Monitor
I have a Toshiba 50h71 with nothing but a blinking power light and click sound when I plug it in. I found a service manual, I have the TV opened up, and I've got a digital multimeter, but I'm not exactly...
resolder the connections on the board around the caps even though it looks good it could still have a bad connection. While your at it heat up the solder connections around other components. If this doesnt solve you problem concentrate on the high voltage section of you tv check for open resistors. And bad transistors move from there to your driver chips these may be in the in the form of high output transistor chips. If it is overheating it might be the source of your problem. Check your horizontal and vertical output chips and make sure they are not overheating as well
Aug 08, 2010 | Toshiba 50H71 50" Rear Projection...
My Toyota Camry 1994 V4 is overheating. But I check my radiator and the reverse but there is water inside both of them. But my temperature keep raising. I took it to a mechanic and he suggest I change my...
i had a 1993 with v6 had multipule problems with cooling system mechanic changed water pump and thermostat it overheated on the way home from him i found the little hose missing from inside the overflow tank so it couldnt take back from it i replaced that and it didnt overheat for a couple of months then the hydrulic radiator fad stopped working it was the sending unit on the engine that worked for a couple more months then i found the radiator caps were bad it has 2 of them . ( your radiator could also be clogging up its old ) then a year later the head gasket went car was never overheated bad to where the coolant was steaming out either so that is probably what you are in for its an old car . hope this helps
Aug 02, 2010 | Toyota Camry Cars & Trucks
My screen has shrunk i/3
If the shrinking is vertical a vertical coupling cap has changed value or in some cases the cap coupling the oscillator portion of the chip to the output portion of the chip has opened. The former will be a large cap the latter will be a small cap around 10 ufd or smaller
Oct 14, 2009 | Samsung HCM5525W 55" Rear Projection...
Distorted sound
Poor signal or poor connection to the cable probably. Could also be a speaker issue or the audio board on the tv is failing.
Most likely just poor signal or poor connection on the cable.
Oct 13, 2009 | Toshiba 42H81 42" Rear Projection...
Won't start
sounds like a board related issue. if this were an lcd issue and the vga chip aint fried, then you should be able to power on a separate monitor by pluggin it into the external vga port usually on the side of the laptop. if you get picture and everything on the external monitor then you know you have a failed lcd or inverter. in the event that it does not get picture on the external and the laptop is still greenlit, you may find that there is a more serious problem with the board. i have seen this happen too often recently with overheating video chips. good luck
ruben
Jul 01, 2009 | Acer Aspire 9500 Notebook
Compaq Presario R4000 looses video and freezes after a while
The problem you describe can be caused by two different things. The two are not related to each other in any way.
The first, which is more common on desktop computers than laptop computers, is a thermal problem. The video chipset is overheating and causing a shutdown of the video. It is possible that this overheating is actually the cpu, but I don't think so, based on your description.
The second is the video power inverter chip. The power needed to keep the lcd screen lit up on a laptop is considerably more than what is needed to run the laptop itself. For this reason, a small power inverter chip is installed on laptops. It is usually found under the plastic bezal that surrounds the screen, and usually on the bottom. When this chip goes bad, the symptoms are as you have described.
Here's a couple things you can do before seeing a technician or teaching yourself to take apart your laptop. Plug in a different monitor; an external monitor and restart your computer. You should have a function option that will let you see two monitors at once. (that's the fn key, usually in the lower left of your keyboard). With two monitors showing exactly the same pictures, see if you can recreate your symptom.
If the problem is in the power inverter chip, the external monitor should remain on when the lcd monitor goes black.
If the problem is inside your computer (video or cpu overheating) then both monitors will go off.
good luck
tony
Jun 17, 2009 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
