Question about ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...
NO SOUND - MOTHERBOARD ASUS P5S800-VM
I had the case simply changed on my computer and an additional hard-drive installed. Apparently i have an ASUS P5S800-VM motherboard but the hardware device manager says Realtek AC97 Audio.
I have tried device settings and all the basic answers - my tech went into the BIOS but everything say enabled and I checked volume, playback, plugs and all microsoft help step by step. Could something have gone wrong in the transfer to the other case that i can't see?
If i unplug the speakers it tells me they are unplugged and even the visualisations on media player work. If i plug in the wrong place it tells me.
I have tried to find an external sound card but there none available here for some reason at the moment.
The technician downloaded latest drivers and i updated again last night without change.
I am using Windows XP
  • tracelle2u Oct 11, 2008
    Thank you so so much - gonna try that.
    The device manger says Realtek AC97 installed and says they are working? But will look for the SIS964. Sorry i am a bit of a novice but also did try the speakers and they working as well as other stuff.
    I am so so grateful for having a way forward - gonna try now
  • velut_umbra May 11, 2010
    Are the speakers in working order? Try them with a mp3 player or something. Just check every option before dishing the board.
  • 781 Answers
According to specs the sound is " SIS964 " go to device driver and check to see if sound drivers installed if they are not it will have yellow mark on them.
Try downloading M/soft UAA drivers first and install them a lot of on board sound require them
then when installed go to drivers again and update sound one will go on net and download and install them
I have had boards that said one type of sound but used another driver to get working
Posted on Oct 11, 2008
Bagaimana cara mendownload sound device asus p5s800-vm
Posted on Nov 08, 2008
Is the ms 6540 motherboard compatible with the asus p5s800-vm
what u mean compatible? if u mean u want to change your ms 6540 to Asus P5S800-VM, then i tell u it cannot be done.
first thing that u look when to change mainboard is SOCKET type... ms 6540 have socket type 478 and asus p5s800-vm have socket type LGA775. thats mean your old processor cannot be use in asus. socket 478 is older than LGA775.
So if u want to change your mainboard for ASUS P5S800-vm, then u need to change your processor to... about RAM socket and VGA socket, ms 6540 have same type with ASUS P5S800 (DDR400) so u dont need to change your RAM and VGA (if u use external VGA)
hope this useful, regards.
Aug 18, 2011 | ASUS P5S800-VM Motherboard
Setelah saya instal PC saya tidak dapat Drever vga sama sound mohon bantuannya kalau ada softwere P5s800um
Try english.
Did I see driver, vga and sound missing? :p
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Select motherboard
Select Socket 775
Select P5S800-VM
Click search, select OS
Download drivers
Or try this. Not sure if it is free
http://www.driveragent.com/asus.php
Feb 27, 2011 | ASUS P5S800-VM Motherboard
MOTHERBOARD DRIVER P5S800 VM
Go to the following website to get the driver you need for your ASUS P5S800-VM Motherboard.
http://www.driverstock.com/ASUS-P5S800-VM-driver-download/6-9-10176/index.html
Jan 21, 2011 | ASUS P5S800-VM Motherboard
INSTALLED NEW MOTHERBOARD FROM ASUS A7N8X TO P5S800 NEW BATTERY BIOS SCREEN COMES UP ONE LONG BEEP CONFIGURED TO BOOT FROM HD BUT ALL IT DOES IS GOES BACK TO BIOS SCREEN MAYBE JUMPERS ARE INCORRECT HOW...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 13, 2010 | ASUS P5S800-VM Motherboard
Onboard sound not working on asus pss800-vm
try and install the drive for the mother board
Aug 15, 2009 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
No sound after reinstalled windows xp pro
Yes you will need to re install the audio driver. If you do not
have the original cd for the motherboard, here is a link to the
Audio Driver that you will need.
Download Link:
http://www.driverstock.com/ASUS-P5S800-VM-driver-download/6-9-10176-81148/index.html
Let me no if i can be of anymore assistance.
Mar 15, 2009 | ASUS P5S800-VM Motherboard
ASUS P5VD2-VM SE - Motherboard - micro ATX - P4M890 - LGA775 Socket - UDMA133, Serial ATA-300 ...  Logo
1,217 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
