Key assignment I'm having issues getting the key assignments to work. i set up a profile select the games exe file, assigned all the the buttons to keys, but when i enter into a game none of the keyboard keys assigned to the buttons work while in game. i know the controller is working i use it to play battlefield 2,and tomb raider anniversary and it works fine. Ive used it before on the same games im attempting to create profiles for. ( call of duty 4, crysis, black hawk down, and far cry) but after a hard drive format i havent been able to get it to work with profiles. my os is vista 64 bit ive tried setting it to auto apply profile , apply manually, and set persistent profile and nothing works. please help installed drivers but don't know enough about computer's on how to assign button's.
3 Suggested Answers
  • 100 Answers
SOURCE: I have a Logitech Dual Action and I am trying to
Here's your solution:
Call of Duty Modern Warfare 1 & 2 Rumblepad 2, Dual Action and Precision Gamepad Setup
Posted on Apr 02, 2010
  • 250 Answers
SOURCE: i can map out all the buttons and assign the exe
Hi Shadynski,
Please go to the profiler and apply the " persistent profile " settings
Should work fine within your game
Thanks and have a nice day
J -
Posted on Jun 07, 2010
Volume control
Yes,you can create a Master Volume Shortcut and also assign a Shortcut Key.
Right click on a empty area on desktop, and click on New and Shortcut.
Paste the following in to the location of the item area:-
%windir%\System32\SndVol.exe -f 49825268
Click Next button and give a name to the Shortcut and click Finish.
Now You right click on it and select Properties.
Click Shortcut tab.
Assign your desired shortcut key like F8 or F9 in the Shortcut Key area.
Click OK/Apply
Is There Keyboard Shortcut For Volume Control
Mar 13, 2015 | Computers & Internet
Unknown capacity usb
Run CMD.EXE as administrator
Type following commands and hit ENTER key after each command.
· DISKPART starts the DiskPart program
· LIST DISK shows numeral assigned to disks
note the numeral assigned to your usb stick
The numeral 2 will be used in this example
· DETAIL DISK the info shown will confirm the correctness of your selection
· CLEAN ALL the entire usb stick will be overwritten with zeros
· CREATE PARTITION PRIMARY create a primary partition on the USB stick
· FORMAT FS=NTFS format the partition
· ACTIVE the partition can contain operating system startup files
· ASSIGN the next available letter is assigned to the USB stick
· EXIT exit from the DISKPART program
· EXIT exit from the command shell
Nov 08, 2013 | SanDisk Electronics - Others
I have a samsung SGH G600 mob. phone how do I set ring tones
Adding a personal Caller ringtone
You can make any kind of sound a personal ringtone for your contacts. First locate the sound you want to assign by following these steps:
  • From standby mode, click Menu
  • Highlight My files and click Select
  • The sound will be in either the Music or Sounds section. Highlight the relevent section and click Select (or just press 3 or 4 for quick access)
  • Navigate through the subfolders in either section to find the sound clip or MP3 you want to assign. Highlight the file and click Options.
  • Highlight Set as and click Select. When the pop-up menu appears, highlightCaller ringtone and press Select, or just press 2.
  • You'll be taken to your contact list. To assign a contact to the tone, highlight their name using the up and down nav keys and press the centre selection key. You'll see the confirmation message 'Changed' confirming the change.
  • Click the red End call key to return to standby mode.
Jul 01, 2011 | Samsung SGH-G600 Cellular Phone
I need to know how to turn the phone on silent I have a nokia nuron
Select Menu > Settings > Profiles. Select the the sound profile you want and press the soft key for Activate. You can assign a shortcut to do this by following the procedure on page 25 of the user manual (found at this link)..
Jun 03, 2010 | Nokia 5310 Cellular Phone
I can map out all the buttons and assign the exe file but nothing happens when in game
Hi Shadynski,
J -
Apr 17, 2010 | Logitech Dual Action for Pc (963292-0403:)...
You can start from OPTIONS in the main menu of any game and then choose CONTROLS. There if you have both the options : keyboard/gamepad, then only you can use the gamepad.
Then if you have the Gamepad option there, then select it and configure/assign the gamepad keys for your game. You can do it by going onto an option; lets say ACTION and then click the Gamepad key you want to assign. Hold down that Gamepad key and double click the mouse. There you go.Your Gamepad is up and running for your game.
May 04, 2009 | Logitech Rumblepad 2 Game Pad
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Setting up rumble pad
Ok well here is what i did for using the direction pad to play flatout, a pc racing game, using the Wireless rumblepad 2 controller. First open up profiler, click on d-pad, select assignment, then click new POV assignment. Put a check on FPS style movement. Then click edit, then click new keystroke. Hit record and then on the keyboard hit the up, down, left and right keys. Then hit stop and click ok. click cancel on the window right behind it. So now you are viewing the POV assignment window that we opened before. Here what you do is, say for instance hit the "N" button and then to the right of it you see "pov north", hit the scroll down menu and hit "keystroke Up" for N. Like wise you click the "E" button and for POV east you assign "Keystroke right". And so like wise "keystroke down" for "S" and "keystroke left" for "W". Once you have all that done. You hit ok and just open up whatever game you want to play and the Direction pad should be able to allow you to steer or go in the up, down, left or right direction. Hope these instructions help solve your problem.
Oct 16, 2008 | Saitek Cyborg Rumble Pad Game Pad
Trying to bind my MX400 Mouse's forward and backward buttons inside of games. I've been using the Setpoint tool, tried binding them to keys on the keyboard with no success.
Try setting the buttons to "generic" in SetPoint and then assign fuctions via the game options.
From Logitech Knowledge Base:
The information in this article applies to the following products:
All Logitech Mice
Logitech SetPoint
Most games that support a mouse will give you options to program or assign specific functions to various buttons on the mouse. These games normally look for generic mouse buttons when attempting to bind the mouse buttons to a game function. If the button is set to another function in SetPoint (such as Universal Scroll, Back, Forward, etc), the game may not see the mouse button as available to bind. This mainly affects buttons 3, 4, and 5.
To resolve this issue, set the button you wish to program to a generic value in SetPoint. The following values should be used if you are having problems binding buttons in games.
Mouse Button 3 (The Middle Button/Scroll Wheel):
In SetPoint, assign this button as Middle Button or Generic Button.
Note for MX Revolution users: You must disable Logitech Smart Shift Technology or the Middle Button option will not be available in SetPoint.
Mouse Buttons 4 and 5 (Normally the thumb buttons):
In SetPoint, assign the thumb button(s) as Generic Button. Note that these buttons will still work in most browsers for forward and back. It is not necessary to assign these buttons to Forward and Back in SetPoint for this functionality.
May 15, 2008 | Computers & Internet
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
130 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
