Question about Optoma Televison & Video
My Optoma EP1690 projector stopped working one day (after the warrenty) and I need to figure out what happened (no flashing lights - no nothing, just dead). Is there fuse that may have blown due to a power surge? Is there a service guide available? I don't want to damage the case when I pull it off, and there seems to be something other than the screws holding it on. It's free at the front, but stuck about 2/3 of the way back.
  • 4 more comments
  • jamiefisher Oct 11, 2008
    I already had the regular user manual, but what I'm looking for is a SERVICE manual (with info on opening the unit and servicing it.) Once I get it open, I can look for a fuse, and trace the power with my multi-meter.
    I need to know if there is a fuse (and where it is), and how to open the case.
    I want to know if someone has specific experience working on this projector, or very similar. I got the case open while I was waiting (it was just stuck), but need to preceed with tracing the power...
    Do you think that you'll be able to help me find and test the power transformer, protective components, etc? My knowledge level is as follows: I'm comfortable assembling a PC from scratch (install CPU, Ram, boards... etc), and I'm wiring up my garage from scratch (60A 240V sub-panel, branch circuits, split sockets... etc), and I have been playing with solar panels and batteries (12V DC), but electronics fall in my grey area of experince.
    I have taken some photos of the insides of my projector. I will try to post them for you. Also, as I disconnect more components (because I cannot reach the power supply otherwise) will it even power up without the control board attached, etc? Will I even be able to identify if it has power, or will it be masked by the fact that there is no component telling it to power up? When it was working, and you connect the power cord, a standby light starts flashing, but that is on the cover which is the first thing I had to dis-connect (cover also had the switches, and IR receiver). Next thing I had to lift up was the control board (connects fairly similarly as a high end video card to a PC motherboard). That's where I'm at. The power supply is now partially accessible.
    Pic of power supply, beneath main board (probably just a custom video card)
    Projector top view and disconnected cover inside view
  • jamiefisher Oct 12, 2008
    Well, it seems as though the fuse is blown. It took me hours to take most of the projector apart to be able to get at the fuse and test it! Man, I'll never take for granted an accessible (and user replacable) fuse again! The power supply unit was burried in the bottom of the projector.
    It's a 5A, 250V fuse. I'll have to call some electronic supply stores and see if I can identify the correct fuse. Any idea how common it might be?
    I just hope I can find a replacement fuse, swap it out, and then get it all back together.
    And hopefully it's only the fuse that went. It would really **** to put it all back together and find that it still doesn't work.
  • 899 Answers
If its not a fuse it will need to be tested to see if the power transformer is sending out power, if it is then a protection transistor or other (protective component( pr) will need to be checked , besides that it could be the rectifier area , voltage regulator or following circuts
Posted on Oct 11, 2008
  • 1 more comment
  • jason Oct 12, 2008
    do not apply power with connections not connected! you can dammage other parts of the circutry that will end up taking the extra power.
    By setting the meter to diode check and no power to the unit you can look for continuity starting with the red coil ,then there is a fuse of some sort, labled f and #'s followed or labled pr and #'s followed . if those have connection you will need to then check the transfomer for power output, plug in all connections on the unit ,or you can check the transformer outputs for continuity with the unit unplugged.
    Once you have got this far let me know the results and we will move to the next testing area if needed ( If checking for power set multimeter on 200V AC and check for power in and power out to the rectifiers( the rectifier converts ac power in to dc power out)(diodes)the colored line on the diode represents the negitive side of the component. You can check these also without power to see if they are good if you reverse the leads on it and it is an open it is OK. forward measurements should read about 7 on the DMM
    usually the fuse don't go unless there is a problem , but if there was a power surge that could have done it, if the fuse goes again there is definately another problem and you will have to start checking and looking for a cause
  • jason Oct 16, 2008
    need any more help?
    President:
  • 1,952 Answers
Just use this below link ....ur product manual is available in pdf format
http://www.projectorcentral.com/Optoma-EP1690.htm
  • 3 more comments
  • mohammed marika thambi
    mohammed marika thambi Oct 11, 2008
    there is no flash light means it may also be fuse problem.....so check out the fuse tooo....if the fuse is not blown means..the problem night be in supply that the voltage was not able to fall on the pcb...so watr am suggesting is..if ur familiar with electronic component means u clear ur fault by ur own else give it to authorised service center...any more doubt pls ask me...i will assist u..
    thank u
    just try this...i think the fuse may not be a problem..This replacement lamp refreshes your projector and can add years to
    your usage with the proper projector care. Projector lamps wear down
    with each use just like light bulbs in your overhead lighting or table
    lamps at home. After a few thousand hours of use, the lamp might become
    too dim or eventually stop working. Purchase this replacement and
    you'll be up and running again as bright as the first time you used
    your projector.
    Customer Service: 1-877-722-8948
    mohammed marika thambi Oct 13, 2008
    if u find fault in fuse ...replace that...
After a few minutes the projector turns off, the red light of the light bulb starts flicking
are you managing to get into the menu at all and reset filter and lamp hours?
By the way - although optoma what cheap option for our school, i now get hitachi with 3 year bulb warrenty.... mine BURNT out luckily not at weekend or school may have gone up too - expensive optoma really then if that had happened.
good luck
Jan 30, 2013 | Optoma DH1010 OEM Projector Lamp
Elevator leg will not hold projector up
Hello
You may have the user manual for your Optoma EP1690 DLP projector with you now I assumes. If have, go to its page [14], where the adjustments to elivator legs has been described. If you haven't it user manual with you now, send your Email address to me by Fixya comment box. I've the user manual for your projector. I'll send a copy of it to you by return mail. I can't send it to you by this mail, as it does not allow me to upload PDF files by it. OK.
If you need the manual, indicate the details in the subject line, otherwise I may for get this.
Nov 09, 2011 | Optoma EP1690 DLP Projector
Optoma ep 1690, the on/standby led is flashing green but when I try to turn it on the temp and lamp led's flash twice and nothing happens, the on/standby continues to flash green.
The projector lamp life may have exceeded its safe limit, check your instruction manual, sometimes you have to hold the on or off button for 10 seconds to reset this. All manufacturers are different but that may be the problem.
Here is a copy of the manual, I havn't read it, my solution is from experience of other projectors.
http://www.myprojectorlamps.co.uk/projector-manual/Optoma/EP1690.html
Good luck
Aug 04, 2011 | Optoma EP1690 DLP Projector
Our projector doesn't turn on anymore. Nothing happens when I press the power button, not even the beginnings of the start up process.
I just had the same problem today. All lights flashing and won't start up. Noticed the flashing the other day, but they stopped after i turned it on. Now nothing
Jan 09, 2010 | Optoma Office Equipment & Supplies
Just turned projector on - lights are flashing and nothing is working... can it be reset??
which lights? could be the lamp has expired, the colorwheel stopped spinning, the ballast/power supply had burned out, or the fans have stopped. if it's the lamp light, replace the lamp.
Nov 01, 2009 | Optoma MovieTime Digital DVD Multimedia...
After being on for a while sometimes 10 minutes, smoetimes 2 hours, the projection loses color and flickers, I can hear a squeeling noise, and eventually shuts down
Mine does the exact same thing, but usually before it overheats and shuts off. This started after I replaced the lamp the third time. I haven't found an outside solution to this, but pointing a floor fan at it to keep it cooler works for me. Did you ever find a resolution?
Sep 09, 2009 | Optoma EP1690 DLP Projector
My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Mar 01, 2009 | Optoma HD65 DLP Projector
Optoma ep721 remote problem
return the projector (still under warranty, if bought new). if it's used, reset the settings on the projector to factory default. if still nothing, replace the remore.
Sep 24, 2008 | Christie 38-VIV211-01 LCD Projector
Televison & Video Logo
803 people viewed this question
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
