Question about Great Plains Industries Gpi& Fuel Pump
Water in fuel light on saab 93
Water in fuel
  • 50 Answers
You can pick up a bottle of gas treatment at any auto parts store. they run between 2 and 5 dollars. water in fuel light on saab 93 - moz-screenshot.jpg it is not good but not necessary to use one of these bottles every so often. pour one of those in your tank after u fill up on gas. and u should be ok. also, the cheapest gas around isnt always the best. chevron with techron is great. if u fill ur tank with chevron gas once every 6 months or so it will help your car dramatically. the techron is designed to lubricate everything in your engine and keep it running well. i hope this helps you.
Posted on Dec 04, 2008
L have dran my fuel after realise fuel is mixed with water. l start my car after putting another fuel it is starting but when driving it stop the engine after a distance l start it again and it starts but...
Did you drain the fuel tank properly after finding water in the fuel? Water is heavier than petrol, and will drop to the bottom of the tank where it is picked up by the fuel pump.
I see you have drained the fuel, but did you take out the tank to make sure there is no water in the bottom or in the fuel filter, and finally make sure there is no water in the carburettor and fuel lines.
Mar 12, 2015 | Toyota Cars & Trucks
Draining fuel tank on nitro 09 got water in there
Have to remove the tank to get all the water out, then refuel . Fit a new fuel filter .disconnect the return line at the fuel rail, work the fuel pump to expel any water from the fuel lines and rail ,connect the return line and start.
Sep 21, 2014 | Cars & Trucks
Fuel in water
Mr. Harris, My advise is to drain the water and fuel mixture from your fuel tank,remove if is easy the fuel tank and completely dry it up,Go by the engine bay and find the fuel pipe which is coming from the tank to the injection system where probably is a fuel filter,renew the fuel filter, blow air in the pipe from the engine side towards the fuel tank-but before you do blow air in the pipe be sure is not connected to the fuel tank,for not sending the water back in. If you did not start the car since water went into fuel,means that you finished with the above,by connecting everything and put fuel in the tank and start the engine. If you did have the engine running when water went into fuel,means that you have to remove the spark plugs and whilst are out and the fuel tank is clean with new fuel and fuel filter make the engine spinning second to second for 2-3 minutes so as the any old fuel to push out from the spark plug holes. After clean your spark plugs or renew them and also before running the engine is good to put an injection cleaner additive in the fuel tank. Better to put fuel up to a quarter of the tank and run it treating all the system.
Apr 03, 2014 | Ford F-350 Super Duty Cars & Trucks
Water in fuel system. removed water
Next thing I would check is the fuel pump. Water may have damaged it, especially if it sat for a while.
Jan 30, 2014 | Cars & Trucks
Location of 2nd fuel filter
one is in the tank.
Filter Removal and Installation
s3o~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
  1. Relieve the fuel system pressure. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel lines from the fuel filter. For additional information, refer to Section 310-00 .
  1. Remove the fuel filter.
    • Loosen the fuel filter clamp screw.
  1. NOTE: Make sure that an audible click is heard when installing the fuel lines. Pull back on the fuel lines to confirm engagement.
    To install, reverse the removal procedure.
Filter -Water Separator Removal
s3o~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Smoking or open flame of any type must not be present when working near fuel or fuel vapor.
s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The fuel system contains pressurized fuel after the vehicle is shut down and will maintain this pressure for a long period of time.
  1. Disconnect both battery ground cables. On vehicles equipped with dual batteries, refer to Section 414-01 .
  1. Open the fuel filter/water separator drain valve to release the fuel pressure. Completely drain the fuel filter/water separator assembly.
  1. Disconnect the fuel supply and fuel return lines.
  1. Disconnect the two cylinder head fuel supply lines.
  1. NOTE: The turbocharger compressor manifold is removed for clarity.
    Disconnect the electrical connector from the fuel filter/water separator.
  1. Remove the fuel filter/water separator from the vehicle.
    1. Disconnect the exhaust back pressure sensor electrical connector.
    1. Remove the fuel filter/water separator bolts.
Installation
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Clean all the fuel residue from the engine compartment. Failure to do so can cause personal injury or damage to the vehicle.
Nov 19, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
Ford suer duty 250 diesel has diesel in water
I think you mean that you have water in your diesel fuel. Open the valve behind the fuel/water separator and drain out some of the watery fuel into a pan (place pan under the car). If you have a lot of water in your fuel, you may need to have a professional drain your fuel tank, flush out the fuel system, and try to salvage the fuel for reuse. I hope this helps.
Aug 29, 2010 | 2005 Ford F 250 Super Duty
My fuel pump is filled with water
FUEL PUMP FULL OF WATER.FUEL TANK ALSO FULL OF WATER.WATER IS IN THE FUEL TANK.THATS HOW YOU GETTING IT IN FUEL PUMP.
Jun 25, 2010 | 2002 Isuzu Trooper
Looking for fuel filter on 2004 chevy silverado ss 6.0, not on frame rail
Here is the steps for the removal and replacement...getting you the picture and location next. 6.6L Engine
  1. Disconnect the negative battery cables.
  2. Drain the fuel from the fuel filter as follows:
    • Install a hose on the water drain on the water-in-fuel sensor.
    • Place the other end of the hose into an approved container.
    • Drain as much fuel as possible from the fuel filter housing.
    • Tighten the water drain on the water-in-fuel sensor.
  3. Remove or disconnect the following:
    • Water-in-fuel sensor harness connector
    • Fuel filter from the fuel filter/heater element housing
    • Water-in-fuel sensor from the fuel filter
Exploded view of the fuel filter (2)—6.6L engine
To install:
  1. Install or connect the following:
    • Water-in-fuel sensor in the fuel filter
    NOTE Check the fuel filter/heater element housing and the filter for a dislocated filter seal or foreign debris. Contamination on the filter/heater housing may cause leakage at the fuel filter. Coat the seal with clean engine oil.
    • Fuel filter on the fuel filter/heater element housing
    • Water-in-fuel harness connector
    • Negative battery cables
  2. Prime the fuel system:
    • Pump the primer located on top of the fuel filter 30 times or until stiff.
    • Try to start and run the engine. If the engine does not start, repeat the previous step.
    • Allow the engine to run for 5 minutes at idle.
    • Check for fuel leaks and clear all Diagnostic Trouble Codes (DTCs).
May 07, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
Hard starting have changed fuel filter four times in two weeks
Either carry a lot of fuel filters or drain the fuel tank after it sits for a full two days, You have water in the fuelor a ton of algae. Confirm the water by pouring out the fuel filter. Any water will be obvious. The water in the tank will separate from the fuel if left standing. Then the water can be drained out the bottom of the tank.Water in the fuel can blow tips off injectors so take heed. and good luck.If you don't have a fuel water seperator, consider having a RACOR separater installed.
Sep 23, 2009 | 2007 Dodge Ram 3500 Quad Cab Laramie
Fuel gauge
Water in fuel
During refueling, it is possible for
water-contaminated diesel fuel to be
pumped into your tank. Your vehicle
fuel system is equipped with a fuel
filter/water separator to remove water from the fuel. The WATER IN
FUEL light will illuminate when the ignition is turned to START (as part
of the light function check) and when the FCM/HFCM has a significant
quantity of water in it.
If the light illuminates when the engine is running, stop the vehicle as
soon as safely possible, shut off the engine, then drain the FCM/HFCM.
Refer to Draining the FCM/HFCM and changing the fuel filters in the
Maintenance and Specifications section of this supplement for the
drain procedure. Allowing water to stay in the system could result in
extensive damage to, or failure of, the fuel injection system
Jan 30, 2009 | 2004 Ford F350
Great Plains Industries Gpi& Fuel Pump  Logo
619 people viewed this question
Top Great Plains Industries Garden Experts
Steve
RSole
Mai Lor
Are you a Great Plains Industries Garden Expert? Answer questions, earn points and help others
