Pink Vertical Line on HP dv6439nr
I have had a pink line running vertically down my laptop monitor approximately 1/3 of the way across the screen from the left for about 3 or 4 weeks now. It's a HP Pavilion dv6439nr that I bought on November 30, 2007 so I still have my 1-year manufacturer's warranty in effect. From what I'm reading online, is this covered under the warranty? Can it be fixed? There has been no bumping, dropping, etc.; I am extremely careful with my laptop! Any help? I would really appreciate it!! Thanks
    Genius:
  • 1,605 Answers
Screen need to be replace. call hp support and get a RMA.
Posted on Oct 12, 2008
Screen pink vertical lines
Probably the tft screen, this can be easily tested by plugging an external screen in. If they both give the same issue, you have a GPU issue.
Dec 14, 2013 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Pink and blue vertical lines through
It could just need the print heads cleaning or aligning
If you are not sure contact the shop you purchased your printer from it is under warrenty for 12 months
Apr 03, 2010 | Computers & Internet
Pink/purple vertical line visible
Anytime you see visible lines running through a display, this is usually an sign of an eminent screen failure. It could stay that way for weeks or the lines could multiply and then it could fail. There is no repair for this, only screen replacement.
Feb 20, 2010 | HP w17e Monitor
How to remove pink line on my lenovo
Is it a pink line down the screen vertical or horizontal. Most likely it is a screen problem and you will need to replace the screen. Check the repair directory on FixYa.com for a reputable laptop service to take care of the problem if you are not comfortable replacing the screen yourself.
Aug 02, 2009 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
May 25, 2009 | HP f2105 Monitor
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Vertical lines in my laptop screen
I know not everyone has this ability, but if you can, go to a friend's house and hook up an external monitor to your laptop. You may need to use the function keys to switch from LCD to external, but if the lines go away on the external, you have a bad LCD. If the line shows up still on the external, then your problem is either:
a) video driver (free, easy fix)
b) bad inverter (video 'outputter') ...approximately $10-50/varies + labor costs to replace
c) bad video card/motherboard ...usually between $200-$400 + labor to replace
Hope this helps - please be sure to rate my answer :)
Sep 29, 2008 | Computers & Internet
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Apr 09, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Computers & Internet Logo
444 people viewed this question
David Payne
David Payne
