Question about Tomtom GO 700 GPS Receiver
Reception my go 700 loses reception in built up areas like london which is understandable, i was thinking of buying an external antenna, will this help or am i wasting my time and money. many thanks keith.
  • 784 Answers
I'm not sure that would help at all. An external antenna is useful if you are inside a vehicle to get around the signal being blocked if your gps is inside but from the sounds of your description, you are being blocked by the buildings. What you need is line of sight to the satellites so the gps can triangulate your location. The more satellites it can see, the better. If it cannot locate at least 3, it will not work.
Posted on Oct 11, 2008
When I press Weather/Snooze the radio emitts a high pitch sound like a whistling. I have the radio set to voice, I have verified the channel 162.4750 for my area. I have a scanner tuned to that same...
Solution #1
Some counties have two frequency channels. check this URL address to see if you have another frequency channel for your area- http://www.nws.noaa.gov/nwr/indexnw.htm. If you do, try the other frequency channel for your area.
Solution #2
You may be receiving a poor reception quality because of where the radio is located or the antenna's positioning. First play with the antenna until you get a better reception. If this doesn't help, try moving it to a location near a window or outside room. If this doesn't help, you may have to buy an external antenna from an electronics store and hook it up to your radio. If you still have your WR-100 Owner's Manual, they have a page in there for reception (page 12), and it lists in there their suggested weather radio antenna.
Solution #3
It may not be anything you've done at all. It could be the weather station's transmitter itself. May you should call your local NWS office and plea your case to them.
Sep 13, 2010 | Midland WR-100 Weather/RDS Radio
Is there a external antenna or booster for toshiba satilite m115?
With pretty much all laptops these days with built in wi-fi there is no external antenna, rather the antenna is built into the top corners of the screen, so you cant see it. Therefore there is no booster you can get.
I you wanted to get better reception you need to put a larger antenna or booster on your wireless router/access point.
Oct 12, 2009 | Toshiba Satellite M115-S1061 Notebook
Ique 3600 antenna reception problem
How long does it try to find the satellites? If it trys for a half hour of more with no results, the antenna may be broken. I have read in other forms that people have added an external antenna and their units would then work, evfen with the built in antenna broken.
Feb 25, 2009 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi 760 loses satelite reception. Tried to reset to factory settings and still having problem.
You may need to buy an additional external GPS receiving antenna. I did for my 750.
Because we love our electronics so tiny, they use an internal antenna. The gold input on the back of it, is for an external antenna available for under $20 from ebay. I used it when I lost reception in NYC, and also in rural areas. The external one has q magnet on it, and you can put it on the roof and have the cord come in your window to the unit (better than arm out window!)
check here - where i bought mine
http://cgi.ebay.com/AMPLIFIED-GPS-ANTENNA-FOR-GARMIN-NUVI-760-750-770-780_W0QQitemZ220265873242QQihZ012QQcategoryZ73348QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
Enjoy, NGK
Sep 03, 2008 | Garmin GPS
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
Unable to acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My Gamin Nuvi 660 Solution
External antenna - Garmin 25MCX low profile remote GPS antenna
I have been experiencing the same problem many have been having with the Nuvi 6xx and 3xx series giving an error message “Lost satellite reception”.
My problem started mid April 2008 and got progressively worse. I would use my GPS on weekends and it would work perfectly for the first 10 – 30 minutes and then would loose satellite reception, rendering it useless.
I bought my Nuvi 660 when it first came out in October 2006 for just under $700 and is now out of the 1 year warrantee.
I called Garmin Technical Support and we checked my Software version (4.40) and more importantly my GPS SW version (3.00). According to the tech I had on the phone, the GPS SW version was more important then the Software version. It was in fact already updated to 3.00, I did master reset, after master reset, but regardless, nothing helped.
I contemplated what I should do.
Return mine and get a refurbished unit from Garmin for $225 with only a 90 day warrantee?
Buy a new Nuvi 660 for around $300
Buy a new Nuvi 2xx series with fewer features for $200 to $275.
Buy a Megellian GPS?
I read through this forum and came across one person that was told by Garmin “that they are aware of an issue with some Nuvis involving the failure of a diode in the unit that senses whether or not an external antenna is connected.” Apparently this diode failure is caused from the high heat these units experience from being left in a hot car for long periods of time. This would explain why mine would work in the beginning and then die.
So my thinking was, if the diode “thinks” there is an external antenna attached when it isn’t, what would happen if I “did” connect an external antenna?
Garmin recommends the Garmin GA 25MCX low profile remote GPS antenna for the Nuvi 660 and costs $31.49 (not sure about additional costs for tax and shipping)
So I purchased the NEW antenna from a seller on eBay for $25.90 total and IT WORK FLAWLESSLY.
Just to make sure it really was the new external antenna that was working and not the unit coming back to life, I started my 3 hour journey with the external antenna NOT connected. As usual it lost satellite reception in about 15 minutes. I plugged in the GA 25MCX and it immediately connected to the satellites and never lost them.
I repeated the same process coming home and once again, I connecting the external antenna after the unit reported loosing satellite reception, and it worked perfectly.
Conclusion: if your unit is experiencing loosing satellite reception, and is under warrantee, return it ASAP. If it’s out of warrantee, get an external antenna. There are other manufactures of external antennas and all should work as long as it has an MCX connector.
Side Note: This external antenna also worked perfectly on a friend’s Nuvi 350 with the same problem.
I wanted to share this with everyone because I’ve been racking my brain for months over this. I hope this helps.
May 04, 2008 | GPS
Razr V# lost service after using external antenna
I have the same problem. Contacted 3rd party tech, take sharp pick or equal and there is supposedly a button in the very center of the antenna port of the phone. gently push the pick in the center of the jack and it will trip the switch. I tried it on my second damaged phone and it worked, so far.
Nov 24, 2007 | Motorola Mobility RAZR V3
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
Internal Antenna not working anymore
if you do a search at pdaphonehome.com a guy has replaced his antenna and provided step by step instructions for how to do it yourself with pictures. I don't know if frying it can make sure getting a new antenna will fix that but thats something you can try before replacing.
May 12, 2007 | Samsung SCH-i730 Pocket PC
Tomtom GO 700 GPS Receiver Logo
35 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
