Question about Olympus Stylus 760 Digital Camera
Blurred images My camera takes pictures fine with the flash on. However without the flash it makes a funny almost grinding noise when it takes the picture and then the picture is slightly blurred. What could be causing this and how can I fix it?
    Problem Solver:
  • 6 Answers
This is mainly due to the slow shutter speed selected by your CAM. in low light situations the cam chooses a slow shutter speed to expose the image adequately. Any shakes that may have caused during the shutter operation will cause the funny images.
use tripod or other kind of support to your camera while shootiing in low light (indoors) without flash.
Posted on Jul 30, 2009
I have a blurry image distortion in the center of the picture only- everything else looks fine- a solution to my problem?
is the central of lcd divice bumped ?
1-are your lcd device show the correct image without any blur before taking the image ?
2- or this blur shown after taking the picture ?
for the first : your device lens should be clean through inner side.
for the second : the lcd should be checked , since the center of lcd may be bumped.
please let me know your checking result.
good luck
gorbesia
Jun 14, 2011 | Nikon Coolpix 4600 Digital Camera
On my sony dslr a 300 the steady shot warning flashes at the bottom of the view screen like it is not able to steady the shot. this makes it is very hard to take a clear picture without it working...
Before you junk it, double check to make sure steady shot wasn't turned off. Also see if raising the ISO settings and increasing the aperture size fixes the motion blur (this will make image noise and depth of view blur increase though). Lastly Try resetting the camera to factory settings as a last resort.
Hope this helps.
Mar 25, 2011 | Cameras
How to switch off the flash in Canon Power Shot A510
in the take picture mode, press the button that has an image of the flash on it (the top of the circle) on the right, and keep pressing it until you've selected the image that shows the flash crossed out.
Mar 27, 2010 | Canon PowerShot A510 Digital Camera
The display does not come on, there is a "busy" sign flashing
Sounds like the problem Canon had to fix for me with my S2 IS which did the same thing. My camera shot blank pics. It turned out to be a stuck shutter. The camera makes all the usual noises, but the shutter is stuck closed.
Sep 08, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
How do i get this blurring image of my camera when i take pictures
Check if your flash is still working. In autofocus(AF) mode, your pictures should be fine.
Aug 13, 2009 | Samsung S760 Digital Camera
Nikon D40 shutter speed problem
The D40 will not take great photos of an indoor event without blurring or noise. You need a fast lens and a high ISO using the popup flash or on camera flash would be ideal but some of these events you can not use flash. All these images I shot with a Nikon D40. http://www.facebook.com/home.php?src=fftb#/pages/Keller-TX/Raving-Design/78762448229?v=photos&ref=ts Learn to use the camera for ur events. Experiment it's all about trial and error. Ray
Dec 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Blur image
I am having a problem with blury pictures. Every one I take is blury and it also seems the flash wont go off. Now the pictures are blury even in the daytime. Anyone that can help me please do!!!!
Mar 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
When i dont use the flash on a nikon it is blured
When taking a picture the camera needs a certain amount of light to hit the sensor before it can record a good image. If you are outdoors in the sun and the camera still takes blurred pictures due to a long exposure time then there is a malfunction. In bright lighting situations the camera should decide on its own not to use the flash. For indoor situations the camera has to either supplament the available light with the flash, or increase the duration of exposure to collect more of the existing light. There is no way around it - the sensor needs a certain amount of light to create a quality image. On some cameras you can override the shutter speed setting and force a fast exposure but without proper lighting you will just end up with dark images. You might also be able to override the F setting to the lowest possible value which would let in the most light. However, these cameras are generally very good at deciding how much light they need to take a quality image. If the flash is set to auto and the camera decides to use it then there is simply not enough light to get an exposure with a fast shutter time. This is one of the factors that gets better the more expensive the equipment is. Higher end point and shoot units and SLR units can collect more of the available light with their larger lenses and thus get good exposures in lower light conditions while still maintaining fast shutter speeds. Additionally "image stabilized" cameras help compensate for this situation by electronically assisting the photographer in stabilizing the image - allowing longer exposure times to be shot hand-held. You could also try a tripod if that is appropriate to your needs, that would help you shoot longer exposures in low light without so much image-wide blurring. Of course anything in motion will still blur. David Millier Advance Camera Repair
Feb 18, 2007 | Nikon COOLPIX S6 Digital Camera
Blurred images with no flash
First, try to get more light, particularly natural light (window); second, try using shutter priority (S mode), setting the shutter speed at not less than 1/50, faster if you are shooting motion/action (check the Properties of the blurred pictures that you've been getting in Camedia software - the shutter speeds are probably too slow because of the low light), and experiment with higher ISO settings (either 200 or Auto, not 400) though there's a trade-off in noise levels.
Sep 11, 2005 | Olympus Camedia C-3020 Zoom Digital Camera
Olympus Stylus 760 Digital Camera Logo
172 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
