Question about Magic Chef Kitchen Ranges
Very old Magic Chef gas range needs new safety valve
No model number, but has a double pilot light system and the safety valve is ancient.  What I need to know is if Part No. 74010590, a replacement safety valve, will work for me.  I've got a picture of the setup and both safety valves are four inches long and approximately the same shape, but I was hoping someone could confirm before I ordered the part.
http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=74010590&cart_number=9184017_42427&brand=MAC
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
Magic chef gas range top burners will not stay light
This problem is almost always due to a defective gas valve. If you decide to replace the part yourself remember safety 1st, turn off the gas and disconnect power to the range.
Nov 16, 2011 | Magic Chef Kitchen Ranges
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Our MAGIC CHEF gas range has a pilot light that comes on, the ignitor comes on, but the oven does not work heat. Any ideas would be appreciated.
First off, decide which you have, a pilot lite or an igniter coil. In electronic controlled units, when the oven won't light, as long as there's gas available, 98% of the time the igniter is bad, even though the old one may glow and seem to be very bright, it could have a small hairline crack in the ceramic, which would not allow the proper amount of electrical current to travel to the gas oven safety valve, which would then make it open and release the gas. A new igniter works almost every time.
Jul 03, 2011 | Magic Chef 31000 Gas Kitchen Range
Oven pilot light is on, but burners will not light. pilot light burns larger when trying to turn burner on. Do I need a new thermostat?
The thermostat is doing it's job if the pilot gets bigger. When you turn on the thermo, it does 2 things: Makes the pilot bigger and supplies gas to the oven safety valve in the oven. The bigger pilot heats up the bulb from the valve and the stuff inside expands and turns on the main gas. The oven cycles when temo is reached by making the pilot smaller. The most common problem is that the pilot doesn't get big enough to satisfy the valve. Take out the pilot burner ***'y. (7/16" wrench for the nut). Replace the pilot burner. The part is probably a 5414S030 if the valve bulb is located parallel to the ***'y.
Sep 30, 2009 | Magic Chef 31000 Gas Kitchen Range
Pilot lit, ignitor glowing, oven will not light
A pilot light and a ignitor do the same thing. no unit would have both.
Perhaps you are confusing the thermo-coupling for an ignitor. An ignitor (glow plug style) is ceramic with a conductive coating on the end powered by electricity supplied by two high temperature coated wires that connect to the oven controller.
A replaceable thermo-couple looks like a copper tube with a elongated bulb at one end and a fitting at the other. The bulb is placed in the pilot flame and the fitting screws into the gas valve.
I am looking at a exploded diagram for the model number you listed. The unit uses a "safety valve" with the thermo-couple incorporated into it. To see the exploded view, click here If
you are asked for a model #, use CPL1100ADW. In section 2, gas controls, Diagram location 17 is the safety valve. Click on the part photo for a better view of the valve.
If you have any questions, let me know. Hope this gets your unit up and running again.
Please take the time to give this solution a fix ya rating,
clarkco
Feb 19, 2009 | Magic Chef CPL1100AD Gas Kitchen Range
Location of pilot light on bottom of an old Majic Chef gas stove
please send model number...and how old in or about years..onthejob
Jan 01, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Lighting pilot light
The model number you gave is judged incomplete by the Magic Chef website, yielding this error:
----------- About Model Numbers:Model Numbers are made up of both alphabetical and numerical characters, and look like this: CEC1536 ----------  Once you have located a similar model number, you should be able to find a downloadable manual here:
Magic Chef manuals
Nov 24, 2008 | Magic Chef 31000 Gas Kitchen Range
I have a 1948 Magic chef gas oven.Model # 8620. The gas was turned off at my home and the pilot light on the oven went out. The gas is now on and I need to relight the pilot light. I am not sure on the ove...
You did say 1948, as in 60 year old range?
Well, gas ranges did not have fancy safety valves or things like that back then. Most likely when you turn on the gas, a small amount of gas begins escaping at the pilot orifice. Then use a long handled lighter to put a flame there. Pilot should light right away.
Oct 11, 2008 | Magic Chef Kitchen Ranges
Kitchen Ranges Logo
63 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
