I was listening to music using media player and there was no problem.
After sometime i closed my system for about half an hour then when i opened it media player was not playing mp3 format rest all was playing fluently.
Although real player is playing the mp3 files normally.
I am using windows vista ultimate 64bit version.
Comments:
Oct 11, 2008
- Thank's for your concern Jeff but i have already tried that but it didn't helped.
Oct 12, 2008
- Done everything you said Jeff. Still no luck.
Is there a way i can reinstall my media player?
Oct 13, 2008
- Hi Jeff.
That update is not for my system (windows says so).
I think i will have to do a reinstall of my os.
Are you aware if there was a windows software update before you restarted the system? What i suggest is to restore the settings back to the working time.
You may run the system restore. Just follow the instructions below.
1. click on start then go to All programs, click on accessories then click on system tool and system restore.
2. a pop up window will show up. just look for a specific date to click on to restore the settings back to the working date and time.
note: your files are still intact.
keep me posted!
regards,
JEff
Comments:
Oct 11, 2008
- Hih Faraz,
If that's the case you may need to download codec. You may try to download the codec below.
You may try to run registry cleaner of your system. Download and run the file below.
http://tinyurl.com/4paxty
If the issue still the same, i suggest to restore the settings back to the time before you encountered the problem then run the codec below.
http://tinyurl.com/6ofvqs
keep me posted.
Thanks.
Oct 12, 2008
- Hi,
With regard to your inquiry, you cannot remove windows media player from the system because it is an embedded application that came with Windows Vista. If this is the case then we might need to try updating your media player.
i cant get my power settings to work in windows 7 The product selector at the bottom of the page...
(More)
i cant get my power settings to work in windows 7 The product selector at the bottom of the page doesnt have seven hence picking VISTA !!!!!!!
When I try to record Vista does not recognise I have inserted DVD or CD when I have inserted a brand...
(More)
When I try to record Vista does not recognise I have inserted DVD or CD when I have inserted a brand new blank disc what is going on?
