Question about Cell Phones
My phone is locked - Cell Phones
My phone it locked my phone it sonny irreckson t610
Posted on Oct 24, 2008
How unlock my phone
What kind of phone lock code do you need?Security lock or network lock
Security lock means try default codes like 12345,00000
If it's network lock,you can unlock your phone by network unlock code.If you need an unlock code visit
WickedUnlock.com
Jun 03, 2014 | Sony Ericsson Walkman W205 Cell Phone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Tip
Unlock your samsung phone in just a simple trick
hi there everyone i would like to share this trick for some of samsung mobile phones
having problem with your phone it always says wrong card????
then try this one...
Note...this code is not working with some of samsung phones...
so just try it...100% it will not damage your phone
just follow this step
1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile
then enter....
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
Input *#7465625# to check the locks....all locks should now be inactive as shown below:
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
hope it will help you
on Dec 30, 2009 | Cell Phones
Phone got locked
hi
you could have mentioned how your phone is locked? whether its privacy locked or network locked. if your phone got locked to the security pin code you can try resetting your phone. else if your phone is network locked you can try unlocking it through codes. you can get the codes from Unlocking4U.com for either resetting or unlocking your phone.
Nov 16, 2011 | Cell Phones
Micromax i am forgotted my phone lock code
Micromax q75 phone lock ? : Solution: If you have not changed the default phone lock code for your micromax q75 phone. Then use "0000"(four zeros is the default code) and press the home button(top left most button and not the green sim 1 button). If you press the green button it will say " Emergency calls only" it means you are clicking wrong button. hope this helps you.
Nov 03, 2010 | Swiss Tech MicroMax 19in1 Multi Tool Clam...
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
How to lock the keys
If it is a flip phone, most flip phones dont offer the ability to lock the keys because they are thinking there isn't a need for that since the keys are hidden by the top of the phone, if it is a candybar phone usually the menu key and the * (star) key are used to lock and unlock your phones, if its a smart phone there may be some options in the settings. You didnt mention what brand your phone is based on the model number sounds like a samsung. you can go to samsungs website and research the model number and usually they have information on how to do everything you need with the phone. most cell phone carriers have this info too, you may have to dig threw the website a little though
Dec 29, 2008 | Sony Ericsson Z610i Cellular Phone
As you asked
ok, so all the locks are off on the phone.
The imei code is valid no one has changed it.
Its possible that the phone has been reported stolen?
Apr 27, 2008 | Samsung SGH-E370 Cellular Phone
Phone locked! Please Contact service center!
My phone is giving message Phone locked! Please Contact service center!)
Dec 31, 2007 | Haier D6000 Cellular Phone
Cell Phones Logo
104 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
