Question about Dell Dimension 8400 power supply ** FREE ** (D8400SATA300W24PINB) Power Supply
Dell Dim 8400 Issues
My 8400 Dell has been acting up for over a year now. After a fresh install it will run well, but after several days, it begins to run bad, and at times just either shuts down or re-boots on it's own. After several times of this, it begins to lock up and goes down hill from there. Then, if I do another fresh install, I go through the same thing again.
I have a feeling that there is either a overheating issue or the power supply is not regulating things properly.
Any ideas on what you may think is causing this. I have tried removing and replacing the ram and all other plugs, but it does not help.
Thanks, Steve
truthfinder@comcast.net
  • truthfinder Oct 13, 2008
    Nope, I tried it.......... Both hard drives are AOK. I beleive it's the power supply...... What do you think? Any other ideas......
  • Dell Master
  • 1,183 Answers
Hi Steve,
The problem that you are facing is most likely because of bad harddrive. As you have already replaced the RAM. To confim the same , run a diagnostics on the Hardrive. You can run the same in two ways .
Check if have the utilitu partision still left on the hardrive
1. Tap on the F12 key 5 - 6 times when you see the Dell splash screen , before windows starts to load.
2. Select Hardrive diagnostics or IDE diagnostics
If the above is no there , look for the dell Rescouce cd
1. Boot the system using the dell Resource Cd.
2. Select 32 bit diagnostics from the menu
3. Run a custom test on the hdd.
If the hardrive fails , replace the same, otherwise try swaping it connector cable with the optical cable.
Thanks
Proton
Posted on Oct 11, 2008
  • Mandeep  Singh
    Mandeep Singh Oct 13, 2008
    If the hardrives, have passed the diagnostics , then you are correct in reaching the conclusion that the power supply is bad . Try reseating the 20 pin power connector on the mothereboard ie. jack is labeled as P1 also reseat the processor power input that is labeled as P2 .
    Thanks
    Proton
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 won't turn-on/respond after having problems
i recommend u to install windows7 ultimate
it will automatically install drivers and solve driver related issues.
Mar 29, 2010 | Dell Dimension 8400 PC Desktop
Dell blue screen tests got data bus system
I presume you ran the 32bit Dell diagnostics. The memory test failure indicates that the memory module has failed. If you have more than one memory installed, you can try removing one at a time and run only the memory test (from Custom test option), this way you can isolate the faulty memory. If you have a warranty for the computer, Dell would replace the memory for you (Check warranty status from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen )
As for your other problem “it just does nothing when i type r for recovery”, you would need to go to the bios, under the “Drives” tree, under “SATA operation” you would need to change option one to two and save and exit. This is applicable on for the Dim 8400. But you would not need to do this if the prvious steps resolve you issue
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell Dimension 8400 PC Desktop
It not a common problem. The problem that you are facing is is beacuse of faulty motherboard. The blinking amber is caused , becasue the motherboard is not able to distribute the power signal to the devices . You can follow the link below to trouleshoot the problem if you are comfortable in opening the computer chassis
http://tinyurl.com/8mkpnm
Thanks
Proton
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
http://www.tomshardware.com/forum/51352-2-dell-dimension-8400-wont-boot
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Cannot print
hi what my have happened is go to
START > PRINTERS > and make sure that your printer is the default printer and not onenote
Jan 19, 2009 | Dell Dimension 8400 PC Desktop
Error reinstalling Windows XP on Dell Dimension 8400
Sounds to me like the hard drive is bad.Download some testsoftware that does not require windows and test it.
http://www.seagate.com/www/en-us/support/downloads/
Jan 15, 2009 | Dell Dimension 8400 PC Desktop
Error in system check 0f00:136c (resource cd, installation cd)
Use MS Systemrestore to restore it to an earlier time or do a complete PC backup. See Dell website below:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=5E3CADE8347C1C3CE040AE0AB5E1
Dec 19, 2008 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
106 people viewed this question
Alun Cox
