Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Thanks for taking the time to check this out! Earlier today I was shooting an interview and I couldn't get the wireless microphone to work so I just decided I would figure it out later and use the Audio 2 that the boom mic would pick up. Later I tried to figure it out and go figure I dug myself deeper and now I'm not getting any audio from Audio 1 or 2. Can you please walk me through the levels each switch needs to be on, on the audio panel so that both the cordless mic works and the boom mic works? I'm using a Samson T32M transmitter which corresponds with a Samson UHF M32 receiver. Thanks again!
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 11, 2008
Pd170 showing and recording elongated images
hello,
technically you have problem in your ccd image, check the ccd the image there a fuse each ccd block. or you can resoldering the thin again.
thanks
otto
Jun 24, 2013 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Scroll wheel not working on pd170
Dear,
the rotary switch needs to be clean, or change ,it depends upon the condition of Roatary switch (Scroll Switch)
Dec 12, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Cannot manually adjust or access menu on Sony Dvcam DSR-PD170
you need to set the auto lock to centre position , and then you need to check the camcorder,if still it doesnt work then you need to take the camera to a good engineer for repairs
Jan 03, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS!!! SONY DSR PD 170 AUDIO PROBLEMS!
if you use original mic(boom mic), rec ch select (ch1.ch2 and ch1) if you choose ch1 it means only 1 channel you want to rec, ch1.ch2 means you select 1 in for ch1 and ch2.input level depend the volume of your input for original mic use mic if the sound around not loud, use mic att if the sound around to loud. +48v for mic original use on, if you use off mic don't work,for input 2 same with input 1.if the original mic don't work try to push the reset button. if don't work, i found that some cam, have bad contac inside the switches
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS! SONY DSR PD 170 AUDIO PROBLEMS
1- Does built-in mic work?
2- Connect direct mic and check sound instead of wireless mic and confirm camera audio circuit.
3- It is Sony professional camera and this should be repaired by Sony qualified technician as you stated that your job depends on it so don't take risk. Attempt of repair by unqualified person is not advised.
Hope this info will help you.
PD170 Record Button Won't Work
any one of the record button will be struck or short...
Jul 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony DSR-PD170 - playback problem
problem is caused by a defective image sensor block.  check with Sony; you may be covered under warranty.
Oct 12, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
350 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
