Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS!!! SONY DSR PD 170 AUDIO PROBLEMS!
Thanks for taking the time to check this out! Earlier today I was shooting an interview and I couldn't get the wireless microphone to work so I just decided I would figure it out later and use the Audio 2 that the boom mic would pick up. Later I tried to figure it out and go figure I dug myself deeper and now I'm not getting any audio from Audio 1 or 2. Can you please walk me through the levels each switch needs to be on, on the audio panel so that both the cordless mic works and the boom mic works? I'm using a Samson T32M transmitter which corresponds with a Samson UHF M32 receiver. Thanks again!
  • Toyota Ed May 11, 2010
    Jordy, I regret to say that I cannot assist you with your issue; my area of expertise is Toyota cars. Please repost to an expert in the Sony area. Apologies again.
    Problem Solver:
  • 17 Answers
If you use original mic(boom mic), rec ch select (ch1.ch2 and ch1) if you choose ch1 it means only 1 channel you want to rec, ch1.ch2 means you select 1 in for ch1 and ch2.input level depend the volume of your input for original mic use mic if the sound around not loud, use mic att if the sound around to loud. +48v for mic original use on, if you use off mic don't work,for input 2 same with input 1.if the original mic don't work try to push the reset button. if don't work, i found that some cam, have bad contac inside the switches
Posted on Dec 01, 2008
Hi am David.Please i would like you to help me. I have Sony pd 170 camera,but from no where the video and the audio started breaking.when i record both video and audio they break when i play out.Please...
Have you tried cleaning the video head with the video cleaning discs. If this does not work then you must use swabs and isopropyl alcohol. If this does not work please contact me for more information.
Jun 24, 2011 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Title-audio problem.
Record channel sellect allows you to sellect right or left channels in line or camera modes. You owers manual may explain it better but if you still have trouble I can help. Larry's Electronics in Sacramento Ca . ledstiles@hotmail.com 916-362-8708
Apr 22, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony pd 170 not releasing tape,it showing c:32:11error, any sugestion plz....
Loading motor is not functioning so that C:31:11 message flashing.Hope cassette is already in.If you can open camera right side cover unload with 3 volt supply at loading motor.It will work
Mar 18, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a PD 170. The LCD monitor turns completely blue
there is problem with on/off switch contact below to have that fixed.
Regards
Sep 18, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
How much use on a Sony HVR-A1U camcorder is too much?
dnt go for it ... u can have better option in z5, or z7 ..or z1 ...most of the camcorder a1 series have problem related to audio ....i will suggest dnt go for it ... its worth taking new dsr pd 170 for the same price
Jun 07, 2009 | Sony HVR-A1U Camcorder
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS! SONY DSR PD 170 AUDIO PROBLEMS
1- Does built-in mic work?
2- Connect direct mic and check sound instead of wireless mic and confirm camera audio circuit.
3- It is Sony professional camera and this should be repaired by Sony qualified technician as you stated that your job depends on it so don't take risk. Attempt of repair by unqualified person is not advised.
Hope this info will help you.
Hissing sound
you can check the monitor audio with earphones if the sound hissing when your recording that means it came from the audio, usually wierd defects cause by bad contact conector.
Jul 12, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Pd170 c31:98 error
The error C31:98 it means Mechanical position fault..here u have to check the adjustment of position and phase Gear
Dec 08, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
157 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
