Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS! SONY DSR PD 170 DV CAMERA AUDIO PROBLEMS
Thanks for taking the time to check this out! Earlier today I was shooting an interview and I couldn't get the wireless microphone to work so I just decided I would figure it out later and use the Audio 2 that the boom mic would pick up. Later I tried to figure it out and go figure I dug myself deeper and now I'm not getting any audio from Audio 1 or 2. Can you please walk me through the levels each switch needs to be on, on the audio panel so that both the cordless mic works and the boom mic works? I'm using a Samson T32M transmitter which corresponds with a Samson UHF M32 receiver. Thanks again!
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 11, 2008
welcomejee
  • 10594 Answers
SOURCE: MY JOB DEPENDS ON THIS! SONY DSR PD 170 AUDIO PROBLEMS
1- Does built-in mic work?
2- Connect direct mic and check sound instead of wireless mic and confirm camera audio circuit.
3- It is Sony professional camera and this should be repaired by Sony qualified technician as you stated that your job depends on it so don't take risk. Attempt of repair by unqualified person is not advised.
Hope this info will help you.
SOURCE: MY JOB DEPENDS ON THIS!!! SONY DSR PD 170 AUDIO PROBLEMS!
if you use original mic(boom mic), rec ch select (ch1.ch2 and ch1) if you choose ch1 it means only 1 channel you want to rec, ch1.ch2 means you select 1 in for ch1 and ch2.input level depend the volume of your input for original mic use mic if the sound around not loud, use mic att if the sound around to loud. +48v for mic original use on, if you use off mic don't work,for input 2 same with input 1.if the original mic don't work try to push the reset button. if don't work, i found that some cam, have bad contac inside the switches
Posted on Dec 01, 2008
Hi am David.Please i would like you to help me. I have Sony pd 170 camera,but from no where the video and the audio started breaking.when i record both video and audio they break when i play out.Please...
Have you tried cleaning the video head with the video cleaning discs. If this does not work then you must use swabs and isopropyl alcohol. If this does not work please contact me for more information.
Jun 24, 2011 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Title-audio problem.
Record channel sellect allows you to sellect right or left channels in line or camera modes. You owers manual may explain it better but if you still have trouble I can help. Larry's Electronics in Sacramento Ca . ledstiles@hotmail.com 916-362-8708
Apr 22, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I need to download the sony DV DSR-PD 150 P driver software
The camera doesn't need drivers, but it does need an application that will take DV input. If you have a Mac iMovie will do that, provided you have the FireWire cable for it.
Apr 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Sony pd 170 not releasing tape,it showing c:32:11error, any sugestion plz....
Loading motor is not functioning so that C:31:11 message flashing.Hope cassette is already in.If you can open camera right side cover unload with 3 volt supply at loading motor.It will work
Mar 18, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I am getin aproblem to capture from my sony pd
If is not fisical break od DV convertor on camera for firewire, then you have problem with damaged ic circle on board in camera. It`s very little chance that you can fixed that by yourself. It will be problem to change main board or circle DV interface. All of  this is complicated and expencive. I recomended you to buy one of Sony cameras ,mini DV. All of that cameras can read DVCAM and you can put everything in your PC. This is cheaper then fixing your camera. I hope that I was helpful!
Oct 19, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a PD 170. The LCD monitor turns completely blue
there is problem with on/off switch contact below to have that fixed.
Regards
Sep 18, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
  • INPUT 1 -
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Hissing sound
you can check the monitor audio with earphones if the sound hissing when your recording that means it came from the audio, usually wierd defects cause by bad contact conector.
Jul 12, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
