Question about Sony KDF-E42A10 42 in. LCD Television
Tvs red light under lamp keeps blinking and it wont turn on
A red light under lamp blinks and wont stop blinking and my tv wont turn on how can i fix this
  • lagaresacruz Dec 29, 2008
    MY TV WONT GO ON THE RED LIGHT BLINK HOW DO I FIX THIS PROBLEM
There was a firmware update from Sony for power up & down problems for the KDFE42A10 among other models which were made in July 2005. If you go to the Sony website (service/support) you can find a link where you can enter your model # and serial # to see if your TV is affected.
The update takes an authorized service guy to come to you home and load the new firmware from a USB memory stick. It takes approx 5 minutes to do. Mine has worked flawlessly for three years now and it was Sony who contacted me to do the update within the first few months I owned the TV.
You should have this done if your TV is affected. Sony indicated that power on and power off problems could begin after six months or so if the update is not done. Sounds like it may be the same issue unless your lamp is bad.
Also, if you have recently had the lamp door open for any reason, you need to ensure it is closed and locked correctly or the lamp light will flash three times in red and won't allow the TV to start up.
This is all covered in the manual under the Troubleshooting' section and is also referred to in the first few pages of the manual where the LED are explained.
Good luck !
Donnieboy - fellow Sony 3 LCD owner
Posted on Oct 21, 2008
    Scholar:
  • 41 Answers
Here is the site with the firmware info he was talking about.
http://www.updatemytv.com/
There is a place to you can put your serial number to see if your model is affected.
Posted on Mar 16, 2009
When I turn the tv on the red lights are flashing then it becomes fixed on the lamp sign keeping its red light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 31, 2015 | Hitachi 50V720 Television
Green light blinking, tv won't turn on
Lamp lifetime is not 100% predictable. A lamp may fail without notice, although this is not usually the case. The picture is more likely to become noticeably dimmer as the lamp nears the end of its lifetime.
While there is nothing wrong with using a lamp until it fails, some customers may want to purchase a new lamp and replace the existing one when they notice that it is aging.
If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no picture on the screen and a red front panel LED indicator will illuminate.
Jan 17, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Jvc projection tv lamp led blinking light(red) wont turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 17, 2014 | JVC AV-32230 32" TV
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Standby light keeps blinking. tv wont turn on
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
May 07, 2009 | Televison & Video
TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Mar 16, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Sony KDF-E42A10 42 in. LCD Television Logo
520 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
