Dell Studio 1555 Laptop Computer 15.6-Inch Chainlink Black Laptop - Windows 7 Home Premium, 2.2GHz I... (883685982843) PC Notebook Logo
James Montague Posted on Jan 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dell studio 1555 screen gets red pixels all over, then goes to a solid color blob
I installed a new screen about a year ago and everything worked fine since then, until recently. At random times, my screen begins getting red pixels all over, then the screen goes to a (random) garbled color.
M Asish
Level 2:
Scholar:
New Friend:
  • Expert 98 Answers
  • Posted on Jan 05, 2015
M Asish
Expert
Level 2:
Scholar:
New Friend:
Answers
98
Questions
0
Helped
33526
Points
210
Cables loose connection, check with your technician
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 08, 2009
SOURCE: HOW TO CONNECT 5.1 WITH DELL STUDIO 15(1555)
Open up Control Panel and navigate to IDT Audio Control Panel.
On the right hand side, there would be an image depicting the jacks available on the 1555. Left click on the respective jacks and change them corresponding to the 5.1 outputs. 21d6042.jpg
Anonymous
  • 225 Answers
  • Posted on Oct 12, 2009
SOURCE: my dell studio 1555 webcam stopped working
1. disable all streaming files and apps first.
2. run system restore, restore the point when webcam was working fine. if fails.
3. uninstall / reinstall webcam driver. if fails.
4.
Anonymous
  • 19 Answers
  • Posted on Nov 27, 2009
SOURCE: my dell studio 1555 is slow in getting started.
if your computer's ram is low try upgrading it
/or maybe your computer is infected with virus try to have a full scan on your computer
/or you hard disk's free space is too low try deleting unwanted files.
Anonymous
  • 1705 Answers
  • Posted on Jul 21, 2010
SOURCE: Cd is stuck in my dell studio 1555 laptop?can you
Look closely at the bezel of the disk drive, you should see a small hole.
Straighten out a paper clip and push it, quite firmly into the hole. This is the failsafe release.
Rodie
  • 629 Answers
  • Posted on Nov 04, 2010
SOURCE: on screen display of dell ac power adapter not
2 possible causes, faulty adapter or faulty motherboard. try to update the BIOS if applicable. If this does not work, attempt to test the adapter on another laptop to confirm if it is working, or try a confirmed working adapter with your laptop. If same issue with another adapter, or if your adapter works with another laptop, it will be a motherboard problem. If the adapter fails on another laptop or if another adapter works with your laptop, you'll need to get a new adapter. Hope this sheds some light. Feel free to rate the usefulness of the information.
Light off on the charger
Either your laptop charger is dead or your laptop dc jack is loose. Try use a spare laptop ac adapter to examine it. If it will work well, that indicates you need a new charger, if it appears the same situation, you should repair your laptop dc jack. If you don't have a spare charger, just get one from the following e-shop:
Replacement Dell Studio 1555 AC Adapter 90Watt 19.5V 4.62A
2answers
I have a dell studio 1555. Upon startup the system won't boot and goes to the blue backdrop with the design and little bird. The cursor is visible but it just freezes at this screen. I tried to go...
Possible that the memory is faulty or the hard disc has errors. You will need to take Help from DELL support before any action is taken specially for estimate.
1helpful
2answers
My dell laptop is showing a blue colored vertical line in screen,i want to replace my laptop.....how?
You can go to support.dell.com to order just the screen. If you are technically inclined, and can follow a service manual (that you can also download from support.dell.com) you can actually replace the screen yourself.
Its not too hard. Without getting into too much detail:
Turn the laptop off.
Remove the battery.
Remove the Power Button display plate.
Remove the keyboard.
Unscrew the hinges holding the screen to the base of the laptop.
Pry open the border of the screen.
Remove the screws holding the screen and replace with the new one.
Dell 1555 not powering up. Solid white light shows on startup button but thats it, no keys function screen is devoid of life. Even the Optical drive eject button will not respond. Can anyone help? Dudsmith
Try removing the battery , and the power cord, and making sure the laptop is off..
Then press and hold down the power button for one minute firm..
Then put the battery back in, then plug the ac cord back in, then try to turn it on..
2answers
My dell studio 1555 webcam stopped working and it says ''close other video streaming devices to start video''
4.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
