I need to know where the tool kit and owners manual are on my1998 royal star tour classic
SOURCE: how do I check the oil level on a 2005 yamaha
You should have a site glass on the side of the motor down low along the frame rail. You will need to have the bike set strait up and down to get a reading so have a friend hold it up right for you. The oil level should be inbetween the top line and the bottom line that is on the case beside the site window.
SOURCE: How do I add coolant to my 2005 Yamaha Royal Star
remove radiator cap slowly pour in 50/50 mixture while burping radiator hose. Better to do while running if possible
SOURCE: looking for owners manual for 2005 v star 650
Check:http://www.stargis.net/webslinger/Docs/VSTAR_650_MAIN_MAN.pdf
SOURCE: how do i change spark plugs and how many are there
Four spark plugs, one per cylinder; the rears may be removed with a 3/8" socket wrench, a 4" extension and a 12mm spark plug socket; the fronts require removal of the motor mounts, do one side at a time with the same tools you used in the rear. The motor mounts require an 8mm allen wrench.
SOURCE: Clutch slave cylinder bleeder location- 1997 Yahama Royal Star To
It's located under the left rear cylinder side cover. Loosen the three bolts holding the side cover to the cylinder; you'll find a "trapdoor" into the crankcase. Open the "trapdoor:, and the cylinder bleeder will be immediately beneath it.
