Question about Akai LCT3201AD 32 in. LCD Television
Bout a post you made
Http://www.fixya.com/support/t469463-akai_lct3201_ad_power_supply
I cracked open this TV how ever I do not see any weeping, leaking or burned capacitors. I have not popped out the power supply nor removed the heat sinks (where the problem may be) I just want to make sure this is the issue before i start to test cut and repair. Is this always the issue with this tv? Wheres the weak link on the power supply and where else are they on the TV?
thanks a head of time for your time.
you can e-mail me at 4running@pirate4x4.com
    New Friend:
    Problem Solver:
  • 13 Answers
On the power supply board if it has capacitors that are raised in the center and not flat then that is you problem.this can be an issue with any model flat screen tv. 80% of the time this is what's wrong.same for computer monitors also.
Posted on Apr 30, 2017
  • Paul Carmichael
    Paul Carmichael Apr 30, 2017
    on the power supply board if it has capacitors that are raised in the center and not flat then that is you problem.this can be an issue with any model flat screen tv. 80% of the time this is what's wrong.same for computer monitors also.
3 Suggested Answers
  • 5 Answers
SOURCE: akai lct3201 ad power supply
Hi doonz75
I got same problem with MLT169A power supply it wont power on. but i found service tech who fixed my power supply. but he stays in toronto, canada. only thing is you have to pull power supply out and mail it to him. his email is jah2mil@hotmail.com
Posted on Apr 08, 2008
  • 2326 Answers
SOURCE: Thanks for repair info on Akai power supply
I'm glad that my experience could help you.
Please let us know when you get it working.
Good Luck
Posted on Aug 18, 2008
My AKAI tv model LCT2715 is not turning on and when I take it off stanby and try turning it on a orange light starts blinking so how do I fix it so I can use my tv again
It may be in the safety shutdown mode due to shorted circuits or failed power supply due to bad caps, I would inpsect the power supply first for caps with doemd tops.
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=akai&megnev2=LCT2715&kategoria=tv&kat2=all
Replacement boards, try www.shopjimmy.com'
Troubleshooting guide:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Mar 05, 2011 | Akai LCT2715 27 in. LCD Television
Akai 4298 plasma....sound no picture, lost manual...any help?
Check the power supply board, Z-SUSTAIN board, Y-sustain board for blown fuses and caps.
Jan 13, 2011 | Akai PDP4298 Television
Hi Ketch1 I have Akai LCD with same problems: TV has red light blinking when plug to power; TV don't turn on. I opened the back and checked all the capacitors and saw those 3 capacitors standing in a...
You need to do more torubleshooting, bad caps can look normal but they can have high ESR which are bad for switching power supply circuits.
Need to check the DC voltages, also try disconnecting the power cables to the backlights inverter board to see if it will come on normally isnce the light blinking can indicating it is sensing shorted circuits so it goes into shutdown/restart mode.
Sorry I cannot find free service manual for you.
Jan 07, 2011 | Akai LCT2721AD 27 in. LCD Television
Tv will not turn on and red power light just keeps blinking
It may be sensing faults circuits in the power supply, inverter boards, etc.
Look at the caps in the power supply first.
Please see my basic troubleshooting guide here:
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Dec 03, 2010 | Akai LCT2701TD Television
I have an Akai LCT2785TA that won't power up. The switching relay on the power supply board doesn't seem to energize wjen commanded (by either the remote or front panel). Do you think I need a new power...
Yes, look to see if it has any bad caps, check the voltages.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 20, 2010 | Akai LCT2785TA 27 in. LCD Television
Akai 27" pure flat tv won't turn on. hear switch clicking...
Check the power supply module first, look for bad caps, shorted out components, cold solder joints, etc. first.
Jul 17, 2010 | Akai LCT2715 27 in. LCD Television
Akai TV power supply problem.
Completely understandable concern. I have fixed 9 AKAI LCT2715 power supplies for other people who have contacted me through fixya.com and 2 through my instructable on instructables.com.
I did notice that you posted this under AKAI LCT3201 TD 32in. LCD Television TV/DVD Combo troubleshooting... I do not remember posting to anything other than the problems concerning AKAI LCT 2715 27in TV's. But in any case this could be the same issue for you as I have noticed a common failure point on AKAI TV's is due to the poor power supply components they use.
As far as trust is concerned I can not really say anything more other than I do keep in contact via email about the parts that are shipped to me to let the customer know when it arrives as well as discussing payment options up front so you know what to expect. I also offer paypal as a payment option and I send an invoice via paypal when the power supply is ready to ship.
Thank you for your question and I hope this helps you understand how this general process works for more cases.
Dec 18, 2008 | Akai LCT3201TD 32 in. LCD Television
Akai lct3201 ad power supply
The MLT169A is a version number issued by MegaMeet in asia who built the supply. The correct part number for the SMPS for that unit is: E7802-005008 and unfortunately they are no longer available... However, there is some good news, those supplies can usually be rebuilt but you need to have the equipment, knowledge to make the repair...
Bill
Mar 26, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
