Question about Gigabyte GA-7VKMP Motherboard
Need system bios update for Gigabyte"GA-7VKMP mobo.
I don't know where 2 find system bios update,My current version;62-2002-001199-00101111-040201-km266a.....Thanx a lot.
  • Anonymous Mar 21, 2014
    why
    Scholar:
  • 54 Answers
Hi bhscam,
Try this it should help you out: http://www.wimsbios.com/phpBB2/topic6731.htmlut:
I hope this helps.
Thank you for using FixYa.com
Sincerely, cyyyd7
Posted on Oct 11, 2008
Which version of Award BIOS supports HT?
I suggest to visit the manufacturer's website. If manufacturer has changed BIOS or Update the BIOS, the patches or new BIOS will be available there.
Jan 25, 2016 | Intel Computers & Internet
Hi, I would like to update my GA-8I848P-G motherboard's BIOS. But I don't know how I can do it. Could you send to a soft to flash the new BIOS?! Kind regards, Grafi
You can get the BIOS flash utility at the Gigabyte website. As far as the actual flashing is concerned, it is a fairly simple and straight forward process. The specifics will depend on the utility that you download. You will need TWO things. The flash utility and the firmware you wish to install. Just a bit of warning, improper flashing of the mobo's BIOS can lead to catastrophic failure of the motherboard, so take care and follow the instructions to the letter.
May 05, 2011 | Gigabyte GA-8I848P-G Motherboard
Wont accept bios update that was sent from packard bell after total failure keeps asking for bios file. also clear cmos feature on board three pins one with white square which i assume is pin 1 but header...
Ga-8SIML is a generic gigabyte mobo and does not need a packard bell bios. you could goto the gigabyte site and get latest from there. If your PB displays a logo at the start then its likely that you will lose that logo as the generic bios will not know it was fitted to a PB machine but thats no hardship.
Be sure to check the board version. version 1.0 takes one type of bios ver 3.2 another and they wont load into the wrong versions of the board. F12 is the latest non beta. I just did two of these recently so i know F12 is ok.
suggest you visit gigabyte site anyway just to check how the bios should be blasted and which version supports which mobo model no..
Aug 13, 2010 | Gigabyte GA-8SIML Motherboard
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
I want to add a grapic card to my motherboard..
you will need an AGP type graphics card for this motherboard, not a PCI-E....hope this helps
Feb 08, 2010 | Gigabyte GA-7VKMP Motherboard
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
2000 pro will My GA-7VKMP motherboard machine running Win will not boot into BIOS orWINDOWS 2000 Pro
well, do the capacitors look distended? (bent out of shape, bulged, burst etc.) is the power supply good? (sufficient power rating, new) other than that the only thing i can think of is that your bios is no good
May 26, 2009 | Gigabyte GA-7VKMP Motherboard
ADA3700AEP5AP 3700 Clawhammer wont boot
I believe that it should work with that chip. If you have the manual for the MoBo try resetting the cmos on the board. That should put every thing back to its defaults. It is posable that it is trying to run it at the wrong voltage.
Feb 29, 2008 | Gigabyte GA-K8VT800 Motherboard
Gigabyte GA-7VKMP Motherboard Logo
225 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
