Question about Dell 5100cn Laser Printer
Deteriorating image quality
When my $20 inkjet can print the same picture better than my $1,000 laser printer, I know that I have a problem.
The setup:
My 5100cn is about 2 years old, and is still on its first magenta and yellow toners (with 10% left). On my black and blue toners I'm on my 3rd and 2nd toner. The blue toner is not Dell manufactured, but the printer's non-dell toner setting is not set.
I've printed under 11,000 pages, but at times I've printed a lot of color heavy pages. The statuses of the imaging drum, transfer roller, and fuser are all reported as ok.
I started noticing when I printed photographs on my printer that they were coming out grainy (or fuzzy). This is particularly noticable in areas that are largely one color (for example, a picture with the ocean as a background.
Upon close inspection, I see lines of darker and lighter shading throughout the picture. These lines (both horizontal and vertical) are easily seen when I run the test prints (such as cyan 20%, magenta 20%, black 20%, or the gradation test). I do not see a problem with on the yellow print. For the other colors (and black), I see horizontal and vertical lines of darker and lighter color interspersed with the correct color level.
Tonight I compare a new color printout of an older document with a printout from 18 months ago. The older document was clearly much better in quality.
Does anyone know what the source of this problem might be?
Thanks in advance.
  • Robert_Lef Oct 13, 2008
    I was concerned about the speed at which the drum wore out, so I started trying to dig a little deeper today. When I went into diagnostic mode and then to print|parameters, I received the following information: the life of the toners was all less than 2000. I assume that this is because I probably removed the toner cartridges some time in during the printer's 10,000 page life. The life of the BTR1, Fuser, Printer, and PHD1 are all approximately 14,900 (give or take 10). However, the life of the phd2=88,450, the phd3=12,318, the phd4=39, the phd5=0, the deve unit 1=75,635, the deve unit 2=75,635, the deve unit 3=75,635, and the deve unit 4=84,049. Am I correct in interpretting this to mean that several components of my printer have seen use well beyond the 10,706 that is shown on the web status interface? Can you think of any explanation for this?
  • Robert_Lef Oct 25, 2008
    Changing the drum made a big difference. I now don't have those horrible lines. I still wouldn't say that the 'solid' colors are solid, but this is worlds better. Thanks.
    An expert whose answer gotĀ voted for 100 times.
  • 188 Answers
Good Evening Robert,
The setting for non dell toner only controls the fuser temperature, and will not cause you any print quality issues. Toner is actually made up of ink and plastic. The fuser melts the plastic to "fuse" the image to the paper. Dell toner is set to "fuse" at a specific temperature. when you use non Dell toners, the temperature required to fuse may be different, and when set to non dell toner setting, the fuser temperature is raised to the maximum to ensure the other toner fuses properly. The down side to this is that you will wear out the fuser sooner then it should.
As far as the print quality issue you are having, it is most likey caused by the imaging drum.
Regardless of the estimated life for the imaging drum as stated by the printer, this is just an estimate. Many things can and will cause the imaging drum need replacing. ( Just yesterday I replaced a black toner in a 3115 that was less then a month old... genuine Dell... with more then 75% expected usage left because it was defective).
On this printer, each of the 3 colors and the black are all independent of each other with the exception of the imaging drum. Even within the imaging drum, cyan and black are independent of magenta and yellow on the first stage of transfer. When you have deteriorated print quality that effects more then one color, the first step is to replace the imaging drum.
The Primary transfer, secondary transfer, and tertiary transfer of the image are ALL contained within the imaging drum.
The chances of having 3 or 4 bad Developers is very very slim. If your print quality issue was related to only ONE color, then I would say you had a bad developer unit ( the 4 items located behind the imaging drum when removed). These are far more difficult and expensive to change.
The BTR ( bios transfer roller ) is the only other item that "could" effect your print quality, however, based on the symptoms you discribed, I doubt it. Besides, if i am not mistaken, the imaging drum kit comes with a new btr anyway.
Although I am sure you may be disappointed with the fact the drum unit is failing while showing it still has life remaining, the solution to replace it should restore your unit to full operation. The unit is light sensative, and effected by physical age as well as the number of prints it has supplied.
Please evaluate the solution i have provided and, rate the solution appropriately to show your support.
Posted on Oct 11, 2008
Dell 5130cdn prints pictures slow, how do I fix it?
The time taken to print a picture depends up on its size, resolution,quality, paper standard. the quality may reduce to normal or draft also resolution, This may produce less quality image. However the paper standard may not reduced as it require the proper temp. to fix the image on paper.
Feb 25, 2015 | Dell 5130cdn Color Laser Printer
How to Differentiate Between Laser Printers & Inkjet Printers
You require a new printer but you do not know whether to buy an inkjet or a laser printer, as you are not aware of the differences between the two. Each user or organisation is faced with the dilemma while buying a new printer. Most customers operate under strict budgetary constraints and it is only normal to consider initial purchase costs and space limitations. However, it is prudent to take into consideration the long-term operating costs associated with the particular printer.<br /> The choice of printer will, largely, depend on your requirements. Inkjet printers are usually ideal for home users who have limited text and photo printing needs. Laser printers are better suited to larger office environments with high-volume and high-quality printing requirements.<br /> The differences between a laser and an inkjet printer are generally categorised into a few broad segments, namely, cost (initial and maintenance), speed, quality, space and networking facilities. It is also essential to understand the technology behind the manufacturing of the laser toners and ink cartridges as this is a major contributing factor towards the cost.<br /> <b>Difference in Technology & Networking Facilities between Inkjet and Laser Printers</b> -<br /> The technology used for inkjet cartridges is simpler and the parts are less expensive than the laser toners. The black inkjet cartridge has only black ink. The color inkjet printer contains two main ink cartridges, for black and other primary colors respectively. The primary colors are then divided into three compartments for cyan, magenta and yellow ink. The primary colors are consequently mixed to produce all other colors. The cartridge contains a reservoir which has compartments with metal plates and a number of tiny nozzles on the print head of the cartridge. The number of holes or nozzles depends on the resolution of the printer. It is usually 21 - 128 nozzles per color. The ink gets heated, when the current starts flowing through the metal plates, after the print command is given. The heat causes vapor bubbles to form inside the cartridge and make the ink swell up. The ink then flows out in droplets from the nozzles onto the paper in a few milliseconds. A vacuum is created (once the ink droplet flows out) which draws more ink into the nozzles ensuring a steady supply of droplets as required. This common technique is called Thermal Inkjet and the coinage of the name 'BubbleJets' by Canon has been due to the bubbling vapors.<br /> The Laser toners use a more elaborate and complex technology. A powder called Toner is used by laser printers, fax machines and photocopiers to print text and images on laser and photo paper. Initially carbon powder was used but now manufacturers use disposable cartridges which can sometimes be refilled. For the laser toners, individual carbon particles are mixed in a polymer which melt in heat. This binds to the fibers in the paper. The laser printers consist of the printer toner and the drum. The positively charged toner gets attracted to the negatively charged drum. The toner is transferred to the paper by the drum. The toner contains special wax that melts and dries in milliseconds. When the toner is transferred, the fuser applies heat and pressure to make a durable image. The fuser system is made up of the hot-roll and the back-up roller.<br /> The high-end laser printers generally come with networking facilities for you to connect to your computer network directly. This cuts down additional costs associated with networking, as is the case with ink printers. The ink printers cannot be linked to a network directly. Networking has to be via a computer, therefore more expensive.<br /> The laser printers are larger in size than the inkjet printers. The latter is, therefore, space saving and ideal for the home and small office users.<br /> <b>Difference of Quality & Color between Laser and Inkjet Printers</b> -<br /> Since Inkjet Printers spill out tiny droplets of ink to print, the resolution is lower than the laser printers. Laser Printers printer better quality text, as their resolution is higher. High resolution also helps the laser printers create precise fonts without fuzzy edges. However, the cost-effective inkjet printers are usually recommended for inexpensive color printing. These can print high quality text, large photo prints, graphics, banners and greeting cards at less than half the price of a color laser printer. Nevertheless, it should also be seen if the cost of ink and paper suits your maintenance budget. Laser printers are capable of producing good quality prints on all kinds of printing paper but the inkjet printers will require inkjet paper to produce good quality prints without any fuzzy edge brought about by 'bleeding'.<br /> <b>Difference in Speed between Ink and Laser Printers</b> -<br /> If laser printers lose out to their inkjet counterparts on account of price, they are way ahead when it comes to speed of printing. Users who need large volumes of printing also prefer the laser printers. Laser printers are more suited to general office use than the inkjets. The least expensive laser printer can print around 10 to 15 pages per minute. The inkjets are usually rated on the speed of draft or quick printing mode, which is suitable only for proofreading purposes. The HP Deskjet 5650, which is a fast color inkjet printer, prints at a speed of 21 ppm Black, 15 ppm Color in the draft mode. However, the speed drops considerably when high quality black text is printed and it also takes longer to print a letter-sized quality photo.
on Nov 10, 2010 | Office Equipment & Supplies
Not printing cyan on xerox 6360
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 22, 2013 | Xerox Phaser 6360 Laser Printer
Which model printer is suitable for home purpose inject or laser
Both types of printers are OK for home use.
The color inkjet printers are cheap printers for color printing, the only disadvantage is if they are not used regularly then the nozzles in the print head can become blocked and if the head cleaning process cannot clean the nozzles then the print head needs to be replaced. These print heads are usually expensive to replace.
If you only want to print black documents I would recommend you purchase a laser printer for the best cost per page printing and they can stand long periods of non use.
Color laser printers are now cheaper, but for photo print quality inkjet printer are better especially when they use 6 or more color print cartridges.
Jan 30, 2011 | HP DeskJet 656cvr InkJet Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
Should I Buy a Inkjet or a Laser Printer?
One of the main considerations when looking at both inkjet printers and laser printers is the amount of usage you anticipate with the device. An inkjet printer works very well for relatively low demands that are primarily text documents. Also, usage that may require some type of color on an occasional basis can be handled very well with an inkjet printer. However, inkjets are not designed for a large amount of production each day. Also, the cost of new ink cartridges can be prohibitive when the volume of printing is higher. Ink cartridges for inkjet types of printers simply do not last that long. For users who prints very often there is no doubt that the laser printer is the better option. Laser printers simply produce a higher quality of color graphic or image.
Aug 15, 2010 | Pacon Office Equipment & Supplies
sounds like a bad drumbur also can be caused by a defective fuser.
Jan 16, 2009 | HP LaserJet 1020 Printer
Print quality problem
Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
Thanks J
Jan 14, 2008 | HP LaserJet 2420 Printer
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Dell 5100cn Laser Printer Logo
479 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
