Question about Dell Inspiron E1505 Notebook
Dell inspiron 1525 not enough memory?
The keyboard shows that it is powered on, but the screen says there isn't enough memory to run and then powers off on its own. I can't get into any applications to try to fix the problem because it automatically powers off. Is my motherboard fried? I recently bought a new charger cord. Could this have something to do with it?
  • 93 Answers
Hi jerry.... its not the problem with charger cord... and it should not be the problem with mother board too. its probably due to more programmes installed on C drive and computer is trying to load more programmes into memory while startup...
switch on the computer and keep tapping F8 key continuously on keyboard.. (stop tapping when you look at advanced boot options)..
select the option safe mode... and hit enter.. you will reach to desktop in safe mode... then
start -> run -> type msconfig and enter
select startup tab -> click disable all..
and apply. ok. then try restarting computer.... even if it exists.... go to safe mode again... and try un-installing un necessary softwares which you dont require.....
Posted on Oct 11, 2008
INSPIRON 1525 NOT STARTING UP
Try taking the battery out then holding the power button down for 30 seconds (this clears the power in the machine), then power back on and hopefully should work.
Apr 15, 2013 | Dell Inspiron 1525 Notebook
Inspiron 1525 mother board problem can i fix?
It does seam like a mother board issue ..but I suggest to check the CPU ..if you can get one with a similar socket ..even if it is smaller on properties...just to see if it works ..cause usually when you do have power indicators..and the fan works ..it shows that the motherboard have power ..so it may be ok ..and only the cpu may have issues or something ..So my advice is to see the socket time (see the specs for the laptop ) ...get another one ...second hand but be sure even if it is a cheap one ..that it is functional ..and try it on ..It might surprise you ..In my oppinion ..this is a clear cpu failure..(remember that the fan is powered up from the motherboard..and if this one is faulty there isn't power present .on the fan nor in the indicator led ..
Nov 22, 2011 | Dell Inspiron 1525 Notebook
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
Hi buddy, can you give me a hand here: i have a dell inspiron 1545 model notebook with vista OS installed. when i turn it on it goes straight on to the bios set up. can you give a help on these issue?...
  1. Check for a stuck F2 key (That prompts system setup)
  2. From a power off State, press Fn+Power and run diagnostics on the system, after the PSA diagnostics, press N to not complete the memory diags, go to the Dell diagnostics, Customer, keyboard test and test the keyboard, then run the HDD diagnostc there too.
Feb 19, 2010 | Dell Inspiron 1525 Notebook
Inspiron 1525 laptop keyboard stuck
if you think thats the cause of the problem.... then you should clean it before it will cause more damage.
clean it with water and let it dry.
Feb 15, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Jun 02, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
My dell inspiron 1525 wont start up
The repair occurs when there was an improper shutdown/power failure. Depending upon the size of the hard disk, it could take a few hours (especially large capacity hard disks) as it need to do several passes over the whole drive.
Just let it run until it finishes, you know if it is still running by the flashing disk LED.
Apr 07, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 memory test failure
Were you able to do a virus scan
try to get on in safe mode by constantly pressing F8 during restar select safemode
See if shutsdown in safemode
Do you here the fans running when it's on
You may just need to do a restore
Let me know what happens in safe mode
Jan 19, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron E1505 Notebook Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
