Question about Frigidaire FAC125P1A Window Air Conditioner
How to install thru the wall fac125p1a 12000 air conditioner
This will be replacing an older unit. any info will be appricated.
bobotfel
  • 236 Answers
SOURCE: Split System Air conditioner
If it is water leaking check the indoor drain pan if overflow with water.If the pan is overflow with water then you need to clean your drain pan and drain pipe. While the unit is operating check the drain pipe if water drip, if no water coming out from drain pipe you need to flush it with water to flush out the restriction.
Try also to check if no icing build in the evaporator fins. If icing is present then you need to clean your indoor evaporator pins and air filter. But if it is clean and still icing is present then your unit is out of gas.
Posted on Jan 29, 2008
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
  • 67 Answers
SOURCE: how large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Posted on Jul 21, 2008
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
A brand new keystone thru-wall air conditioner is installed and plugged in. The power is on but it doesn't work. What could be the problem?
The unit has a start time delay (3 to 5 minutes) to protect the compressor against starting under high after a short time power failure. Most people tend to turn the unit off when it doesn't start when turned on.
Jul 28, 2014 | Keystone 12,000 BTU Thru-the-Wall Air...
Thermostats
Its a saftey in the heater the thermostat is probably fine
Jan 05, 2014 | Sanyo STW0923H2 Thru-Wall/Window Air...
Where does the water drain out of the unit on the frigidaire 10000-12000 btu and the 22000-285000 btu units?
The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
Jul 02, 2011 | Frigidaire Wall Room Air Conditioner...
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
May 08, 2010 | Sharp AF-S80MX Thru-Wall/Window Air...
When i plug in my frigidaire fac125p1a the reset button trips immediately. won't turn on.
compressor has gone to ground. In other words the reason the reset button trips is to prevent any electrical shock due to the compressor going bad. Only way to fix this is to have the compressor replaced
Jul 14, 2009 | Frigidaire FAC125P1A Window Air...
CA15WYSO Air Conditioner
Make sure that unit is slightly sloped toward the outside. Your unit is either level or more probably leaning to the front.
Jun 08, 2008 | Crosley CA15WYR Thru-Wall/Window Air...
Heating & Cooling Logo
536 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
